Results 1 to 12 of 12
Thread: Ryker Down!
    Aug 2007
    Greeneville, TN
    Default Ryker Down!
    My Ryker Rally has been leaking some oil at the output shaft seal for the rear drive. It's in for some R&R on that. First output shaft seal I've heard of leaking.
    Jan 2009
    austria
    had the same - was made under warranty (around 15.000 miles..)
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by chris56 View Post
    Thank you for the information. My service writer said that he was not aware of any of these seals going bad. I know this guy and he is very straight with me. He isn't claiming he knows for sure that no seals have been a problem. Just that he is not aware of any issues. I assume that you've been good since the repair?
    Thanks for the information. Please keep the site updated.
    Jun 2019
    Czech Republic, Europe
    I had the same problem twice - I have my ryker from April 2019. It was fixed on warranty. Firstly they changed only the seal on the final drive. Secondly they changed the final drive and also the drive shaft, because the design of the shaft was supposedly changed on 2020 rykers due to its unbalanced design making the damage on the final drive seal.
    May 2016
    Noblesville, Indiana
    Same problem at 12,000 mile. New final drive unit under warrenty.
    Invalid Emails
    May 2021
    Ontario,New York
    I am hoping my 2021 does not end up with this problem.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Pantera View Post
    Well, this does not align well with my service writers information. Mine is an early 2019. I hope I don't need major surgery on it. but it has been leaking since very early on, if not day 1. It was so slight I wasn't aware of it until recently. I appreciate all the feedback.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Ron, did you ever get your final drive replaced? My dealer has filed a case with BRP but has not been contacted back yet. It has been at the dealer for three weeks last Wednesday. Is BRP usually this slow?
    2019 Ryler Rally , Shock Yellow
    Jul 2014
    Mint Hill, NC
    Shawn Smoak has a fairly recent video with the first case he's seen; replaced the whole assembly as a unit. It appeared to my not so well educated eye that a worn/defective seal was the culprit.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2007
    Greeneville, TN
    I think my original post must have been misleading. My leak is from the gear box, not the final drive. It's the output shaft for the drive shaft that is leaking. And, after the 'Fix'. It's still leaking. It's going back into the shop soon to try again. I hope replacing the seal (again) will do the trick.
    Jul 2020
    Florida
    Ever since you reported your leak at the output shaft seal, I've add that to one of the areas that I regularly check during periodic inspections. I've always checked the rear final drive for leaks, but didnt think about the output shaft seal until you mentioned it.
    2020 Can Am Ryker Rally Sport Touring Edition
