Results 1 to 11 of 11
    Aug 2020
    NM
    Default Spyder vs. Ryker - Five Things You Need to Know Before You Buy
    I often get questions from folks about which Can-Am trike they should buy...the Spyder or the Ryker. I put together a short video highlighting the main differences in my opinion to help someone who is contemplating either trike. Please watch, subscribe to my channel, and let me know what you think via the comments in the video.
    You can check out the video here: https://youtu.be/YfLrpO1k6ps
    Aug 2020
    NM
    Aug 2019
    Stoughton, WI
    Maybe point out that the Ryker is shaft driven, while the Spyder is belt driven.
    2022 RT Sea To Sky
    Dec 2015
    Oakley Utah
    I thought the script and audio were good, but the visuals not so much. The biggest problem you're having is the sunlight from the open door creates too much contrast with the dim light at the back of the garage, particularly since everything about the bikes is black. The bikes are also too close together, I think.
    2014 RTL Platinum
    Dec 2008
    Syracuse, NY
    I agree, and that's after cataract surgery, and no glasses.
    Aug 2020
    NM
    Thanks for the feedback. I'll work to improve my lighting for future videos.
    May 2016
    Mansfield, Ohio
    ???? I'm pretty sure that Rykers have a 'snowmobile type' CVT transmission (belt-driven) and the final drive is belt, just like Spyders. (so they actually have 2 belts).
    2021 RT Limited , Deep Marsala Metallic (red)
    Sep 2017
    Durham,Maine
    They have the cvt trany, witch has a belt, yes, but are shaft driven to the wheels!
    2012 RTL , Pearl
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by knobby View Post
    Nope... Shaft drive only. No final belt drive. The Ryker is marketed as an 'Off Pavement' vehicle. Not a good environment for an exposed belt drive system.
    Aug 2019
    Stoughton, WI
    Primary Drive (Rear Wheel) Shaft
    Transmission Type Continuously Variable (CVT)
    2022 RT Sea To Sky
    Active Member budvoss's Avatar
    Dec 2010
    S.C.
    I just purchased a 21 rally . Drove it only a few miles before i decided i needed a windshield and full rear fender. I owned a spyder for for years in Florida and sold it when i moved to NH. Now i have the rally 900. Same engine as in my skidoo but that is a turbo 900 150 HP.. I like the rally a lot.
