Results 1 to 6 of 6
    Jan 2021
    northeast pa.
    Default check your battery connections
    i just installed a battery tender, and the bolts were only about finger tight, thought i would pass it along,,
    this was on a new 2020 F3-limited..........
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Thank you for the post. A good heads up to all.
    Feb 2017
    As Mike say, "star washers."
    Northern Kalifornia
    Ha, when I replaced my battery for the first time the battery bolts were both tight. However, the first time I inspected my brake pads I discovered that the right front wheel lug nuts were barely more than finger tight. WOW!! why they never came completely loose I have no idea. Many many years ago that happened to my truck after I'd purchased new tires. Luckily I felt the vibration before the wheel came off. Had to replace the studs and the bolts and the wheel. All at the tire shop's expense. Poopo happens from time to time.
    Jan 2021
    northeast pa.
    Quote Originally Posted by Arion View Post
    tell BRP that, not me,,, mine were loose from factory. just letting people know, to check there's, if they want to add star washers , fine..
    i just titened mine
    grip puppies
    Bajaron sway bar
    battery tender
    Quadtrac 165/60's
    Northern Kalifornia
    Are batteries installed at BRP or are they installed by the dealer?
