Results 1 to 10 of 10
    Feb 2021
    LA
    Default Problem installing show chrome backrest 2020 rt limited
    Installing a show chrome driver back rest and need to know the trick to getting the rear seat pan lifted up to install the riser bracket that the backrest slips into. The slingmods video shows lifting or shaking the pan in the middle and instructions show lift up on right side. I can't get either methods to move the pan. Video says loosen bolts and instructions said remove the bolts, the bolts are completely loosened. Any help will be appeciated.
    Dec 2013
    Did you check out this thread, & watch the vid linked, the first one is the important one I think?? But check the rest of the thread, it'll make which clear.
    https://www.spyderlovers.com/forums/...light=Backrest
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    We had same problem on my 2021 RTL. The bracket didn't just slip into the seat pan easily as the video showed. Friend got a little rough with it and finally finagled it in. Hope we can get it out... I have just ordered a new Utopia as the ShowChrome just does not have the features I am used to on a Utopia...ie...larger size pad and easy back/forward adjustment with just a turn of the lockwasher with your fingers. ShowChrome, you have to adjust with wrenches.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Aug 2020
    Georgia
    IIRC, on my 2020 RT there was a wire bundle blocking the lower area which didn't allow the bracket to drop all the way down into the slot. Also, it is a little tricky getting the angle just right. Those 2 large screws are the only ones you need to remove in the seat pan area but it takes some coaxing to get the required clearance after those screws are removed.
    BTW, I gave up on the Show Chrome backrest - very uncomfortable. I now have a Utopia which is better but it pushes my "sit bones" too far forward so instead of my back hurting on long rides, my butt hurts.
    Considering the OEM backrest but the price is outrageous.
    Feb 2018
    Texas Hill Country
    Quote Originally Posted by WilcoJunoHotel View Post
    Have you tried the Air Hawk? I have used one since they first came out - still use the original... love it!
    ONE MORE QUESTION: DID YOU HAVE ANY PROBLEM GETTING THE SHOWCHROME BRACKET OUT OF THE SEAT PAN OR WAS IT AS MUCH HASSLE GETTING IT OUT AS GETTING IT IN? MY UTOPIA IS DUE HERE AROUND MAY 12 OR SO.... THANKS.[/B]
    Aug 2020
    Creal Springs, Illinois
    Quote Originally Posted by Pooch View Post
    Same install issue with Utopia. First thought, that bracket isn't going in there. Had to get rough with it.
    Feb 2017
    Quote Originally Posted by CHUCK1 View Post
    I faced the same problem with my wife's 2021 Sea to Sky. Tugging harder eventually worked and the bracket slipped into place. It was a little unnerving but it did work and so all is well.
    Apr 2021
    FL
    By any chance do you have a link to the air hawk I just purchased a 21 RTL
    Sep 2020
    Middletown, NJ
    Airhawk quality has dropped since I bought 1st one in 2010. The base of the stem leaked on both of mine. 1st one lasted 6 years, 2nd one less than 2 years. Look at the WildAss air cushion as well. On year 3 of WA and so far it's holding.
    Amazon has both brands. Get the large kidney shape.
    https://www.amazon.com/Wild-Ass-Desi...s%2C670&sr=8-4
    https://www.amazon.com/Airhawk-Cruis...13RGDGQ8&psc=1
    2020 RT base , Chalk White
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Tip to get (at least the Utopia) the bracket in; the bracket goes on TOP of the square tube (and the wires run in a channel under it). I used a small plastic trim removal tool inserted between the seat pan and the tube in a hole about 4" outboard from the center to pry the square tube and seat pan apart a little. The bracket dropped right in!
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
