Need info on 2021 RT seat removal to install backrest?
Where can I find info on seat removal to install BRP drivers backrest on 2021 RT?
Steve
Pop up front seat and reach back and push in 2 clips holding rear seat. Slingmods video of seat removal : https://www.youtube.com/watch?v=02xASx27tq4&t=8s
Here are the install Instruction:
https://instructions.brp.com/e-instr...2&val=backrest
2021 RTL S2S, BRP arm rests, smart mount backrest, Pedal Commander, F3 position B handlebars, adj side vents.
Originally Posted by mhan
Like I said, I'm looking for instructions for seat removal for a 2021 spyder rtl, I already have instructions for "BPR drivers backrest" installation. The link you put in is for an aftermarket backrest.
If you watch the video it shows how to remove the back seat.
Lift the front seat, reach under rear of front seat and press the two tabs, lift up on rear seat, unplug wires for heated seat if equipped then remove seat. Takes all of 2 minutes maybe.
Ozzie Ozzie Ozzie
. While the video may be aimed at showing how to install the a/mkt backrest, if you have a look at it, there's also some pretty clear instructions and video of how to remove the seat - starting at about 3 mins 20 secs in - wasn't that what you wanted??
Just purchased the PDF service manual for the 2021 RTL (Ebay) and searched all 770 pages and can't find any instructions for removing the passenger seat. But found some good info on the SpyderLovers forum that explained it. The 2 tabs easily release the seat but make sure you re-engage the tangs at the rear and double check the wiring harness is tucked away and not pinched when reinstalling the seat.
