Results 1 to 10 of 10
    Mar 2021
    Ohio
    Default What size Socket - oil filter lid 2020 RT Ltd?
    What size socket is needed to remove oil filter lid on a 2020 Spyder RT Limited?
    Sep 2014
    USA
    if they are the same as the older models it would be a 36MM. Since its the same engine.
    Aug 2012
    Central Coast, CA
    Yes. 36mm, same for all 1330 engines.
    2020 RTL SE6
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Buy a good socket. It also fits the rear axle -- at 166'# you want a quality tool.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Oct 2020
    Arizona
    Quote Originally Posted by ButterSmooth View Post
    Or
    Get this torque wrench extender. With my torque wrench it converter to 117#, you do not have to worry about the muffler being in the way.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    And I bought is for the other end.
    And this 3/8" drive for the oil filter.
    Equally important, and possibly even more so, remember that the crankcase drain plug requires a T-45 Torx bit and the clutch cover, aka transmission, drain plug is 6mm Allen. Using the wrong tool on the crankcase plug can get you to s**t city.
    Mar 2021
    Ohio
    KX5062,
    Mar 2021
    Ohio
    Snoking1127,
    Mar 2021
    Ohio
    Jaybros,
    Mar 2021
    Ohio
    Trikermutha,
