Results 1 to 25 of 29
    Apr 2021
    AZ
    Default What's the best TPMS to use on a 2021 Spyder?
    What is the best TPMS to use on 2021 Spyder?
    Thanks in advance
    Steve
    Apr 2020
    Edgerton,WI
    FOBO …. LaMonster sells them.
    2019 F3L , Covid Blue
    Clinton, MS
    Fobo 2
    Feb 2019
    Portland, Oregon
    A Slime "no air loss" tire gauge.
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    Do you have a Garmin GPS mounted on the Spyder? Consider their TPS solution.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    I looked at their site but had the impression they were just for 2 wheel. CORECTION: They're for 3 wheel also.
    2021 Can Am Spyder Sea-to-Sky
    Apr 2021
    AZ
    Thanks to every one that had pertinent information to the question.
    Sep 2020
    Middletown, NJ
    The Garmin TPMS looks like a good add-on if you have a compatible Zumo but they are a bit pricey. All recommend you replace your valve stems with all metal regardless of what you decide to get.
    2020 RT base , Chalk White
    Clinton, MS
    Quote Originally Posted by RayBJ View Post
    That's one of the things I like about the FOBO 2 system. So small and light it works well with the rubber valve stems.
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    A word of caution on the FOBO 2 on a 2020 Spyder. I don't know if 2021 model year kept the same tire rim. This is from Lamonster's website:
    These will not work on the BRP Shamrock wheels with out changing the valve stem (Stock stem is too short for Fobo).
    My 2020 has the shamrock rims. I have not investigated what it will take to change the valve stem.
    Jan 2021
    Oklahoma City
    Slightly off topic, but not by much. I just installed my FOBO2 and I didn’t realize until I was picking up tools and trash that there are locking nuts in the box which I didn’t install. Wouldn’t be that big of a deal to install them, but I was wondering if most everyone uses the locking nuts or not?
    Sep 2020
    Middletown, NJ
    You don't 'need' them for the caps to stay on. The gasket friction holds them. They are supposed to help deter thief but - really?
    They may not fit on your OEM stems anyway.
    Jan 2021
    Oklahoma City
    Thanks for the quick response. That’s kind of what I thought...not really necessary but wanted to double check the knowledge base here. I didn’t look to see if they’d fit in the short little valve stems BRP uses and I guess at this point I don’t even care if the locking nuts fit or not
    Clinton, MS
    All this talk about the FOBO TPMS got me to stop and change the batteries with the extra set that came with it. Wonder if I will get over a year and a half on this set?
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    My original FOBO2 batteries died at just under 2 years a couple months ago. Changed them and all was/is well again. But I rarely used the "logged in" feature of the app while riding. Would check the pressures using the app on my iPhone at stops, or before starting rides, etc. I don't "live monitor" the pressures while riding.
    2018 Spyder RT Limited
    Apr 2021
    Washington
    Does anyone have the FOBO 2 on a sea to sky? Do they fit without changing valve stems?
    Jan 2021
    Oklahoma City
    Quote Originally Posted by eschmid2 View Post
    I do and yes they fit with no problem.
    Apr 2021
    Washington
    Awesome! thanks I have both on order - the FOBO 2 and the new sea and sky!
    Jan 2021
    Oklahoma City
    You will love them both!
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    Are the shamrock rims installed on the Chrome Edition RTLs only, but the Dark models have another type? Just wondering if the 2020 RTL Dark model can use the FOBO2 TPMS setup? The rubber valves look pretty short on that rim as well so wondering if anyone can confirm?
    Cheers
    Kevin
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Had Steel Mate (sensors similar to FOBO) tpms on our GL1800. Batteries on it lasted over five years. I learned that correct tire pressure setting was almost impossible without T stems. After having them installed, adjustment and checking with an independant gauge was simple. I understand the tires on a new Spyder have short lifetimes. I will have T stems ready for installation when new tires go on.
    1976 RD400c
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    Highly recommend the FOBO2.
    I have a 3-set on my Spyder, and a 2-set on my Spyder trailer. Work great.
    Customer service... had one of mine on the Spyder (over a year old) that started draining the battery in less than 2 months. Contacted the FOBO guys, sent them a diagnostic (from their app), and they sent me a new device at no charge. Great company to work with!
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    I have a Garmin TPS on my RT. Haven't ridden for 9 months due to health. finally got out today, and the front two TPS monitors didn't work. Checked batteries...dead. Rear still working. Problem...trying to fine BR1225 batteries. The only place that has them in town wants $6.00 each. From Walmart, if I want to wait few days, 5 for 4.99 for same brand. If I need two, I'm sure I will need the third very shortly. I guess I will wait.
    Jul 2013
    Conn.
    Quote Originally Posted by Baron14y View Post
    Do you have rubber valve stems?
    2017 RTL , Grey
    Jan 2021
    Oklahoma City
    Quote Originally Posted by Al_lockup View Post
    Curious, what role do rubber valve stems play with this issue. Not being sarcastic, thinking there might be something I don’t know.
    I have heard of the weight of the TPMS causing enough flex in the valve stem to mar the wheel.
