Best Video for replacing seat on 2016 RT
Hi
I’m going to sell my Spyder and want to remove the Ultimate Seat and reinstall the original. Looking for a video with clear instructions to review before I attempt. The Ultimate was installed for me so I didn’t see how complicated it may be. Thanks!
See this link starting at about 5'15": https://www.youtube.com/watch?v=LSKo9Gn14MY.
It's just the reverse, going from the Ultimate to the OEM seat. The most important point is stuffing a shop cloth in the hole at the rear of the seat so you don't lose anything down into the black hole of Spyder World.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
It's just the reverse, going from the Ultimate to the OEM seat. The most important point is stuffing a shop cloth in the hole at the rear of the sear so you don't lose anything down into the black hole of Spyder World.
Absolutely - stuff a cloth into the space beneath the two rear mounting points. Removing the nut and bolt combination isn't difficult but if you're not careful a nut, or one or both of the metal sleeves through which the bolts are inserted, will fall into the black hole. This I know from first hand experience - sadly. Every bit of information helps!
If you get one of these or if you have one it will make taking that seat off much easier. (Blackhawk GW-9946R Drive Rotator Ratchet, 1/4") or similar. As said above just make sure you plugs the hole. Easy peasy.
