Results 1 to 16 of 16
    Feb 2021
    WA
    Default Need to take off BRP comfort seat...
    does anyone know how to do that? Having hell of a time figuring it out. Windhound
    Nov 2020
    Lincoln, Nebraska
    I believe Youtube has a how to do it video on that.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by Plarimer View Post
    If there is one, I cannot find it. Lots of install videos, but not a removal video for the comfort seat. Looks like you would somehow have to squeeze the plastic clips together from underneath, but does not look easy without breaking them.
    Member ravensrest's Avatar
    Feb 2021
    Grants Pass, Oregon
    Reach under the opening between the driver and passenger seat. You will feel the platic clamp that holds the seat down (it is the bottom of the seat button you push to install the seat). Pull the tab towards the front to release the button; it will pop up thru the top of the seat. Now just push the seat forward. This may take some bumping on the seat handles, but it will slide forward and you can just lift the seat off then.
    BS
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by ravensrest View Post
    BS
    My understanding is the it is the driver's seat, not the passenger seat he is trying to remove. Maybe I was wrong....
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    Seems to me I saw a video where the guy just felt around under the seat for each clip, then put both hands in and lifted - popped right out. He was reinstalling the stock seat, and also did a neat trick with gorilla tape, using that to pinch the soft wings together while leaving a long enough tail on the tape to pull it off once each tab is in the slot.
    Maybe time for a grassroots campaign to get CanAm to use a standard mechanical fastener instead (mutter mumble) ...
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by sKiZo View Post
    The comfort seat has hard plastic tabs where the soft wings are on the standard seat. It doesn't seem to be just a matter of lifting the seat because the tabs are much more likely to break. That is the issue, but I have not tried looking under the seat to see if you can pinch the plastic tabs together in order to get the seat off. There probably is a method, but I have not seen a need to remove my comfort seat yet so I'm not motivated to find the solution.
    Invalid Emails
    May 2021
    Ontario,New York
    Quote Originally Posted by Boilermaker View Post
    Did you ever figure out an easy way to remove the comfort seat?
    Jun 2015
    Ritzville, Wa
    Somehow I get the feeling you're going to have to lift the whole top of the bike up (clam shell) to get easy access to the underside of the seat.
    https://www.youtube.com/watch?v=Mktcr29nDZQ&t=628s
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Invalid Emails
    May 2021
    Ontario,New York
    I was hoping someone had discovered a trick by now to avoid lifting the clam shell.
    Mar 2021
    Michigan
    I seem to remember where someone recommended pulling the hard tabs together with zip ties so it lifts right off. Leave them on while the seat is off and cut the ties when you're done.
    May 2009
    Connecticut
    I just pulled my comfort seat off ( gently) before I sold it on CL . I remember one of the eight clips broke but the person buying it didn't care for 1/2 price and you just push it on.
    Sea Doo GTI-SE 90 Jet Ski!!
    Jun 2021
    Mass, USA
    To swap my OEM seat with the comfort one I literally just grabbed the seat and pulled it out and pushed the new seat in. There's rubber clips that it uses to snap in so you don't need to take the whole bike apart.
    Invalid Emails
    May 2021
    Ontario,New York
    Quote Originally Posted by lokiryker View Post
    We are talking about removing the comfort seat, not installing it.
    May 2009
    Connecticut
    Quote Originally Posted by Pantera View Post
    Just gently pull it off the same way you pushed it on!
    Jul 2020
    Florida
    The tabs on the Comfort seat are hard plastic tabs, compared to the foam tabs that bend easily on the OEM foam seats. Every one of the Comfort seats that I've seen for sale on the FB groups had one of the tabs broken off after removing it from their machines (I've seen 3 this way). I dont understand why they made them this way, probably to cut costs. Its just plain stupid and a cheap way to do it. I know if I ever remove mine, I'll be lubricating those tabs so there is less friction when trying to squeeze those tabs through the little slits.
    2020 Can Am Ryker Rally Sport Touring Edition
