Results 1 to 18 of 18
    Mar 2021
    MD
    Default Must Have's for Frunk?
    I am getting a Ryker 900 shortly and wanted to hear from you about the 'must have's' to carry with you. I have a LinQ bag, but may not always have it attached. What are some things you all think I should have with me at all times? I'm thinking:
    tire pressure gauge
    pen/notepad
    charging cable for phone
    zip ties
    Any other suggestions would be appreciated. Thanks!
    Apr 2021
    Ky
    Rain gear, sun block, phone charger.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    (sarcasm) Wallet with creditcard, and loose change, few bottles of water/ or spirits, helmet, gloves, etc. etc. Just Kidding
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Get the glove box organizer. Useful pockets to keep all that stuff organized.
    https://www.slingmods.com/canam-ryke...pnel?vehicle=4
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Mar 2021
    MD
    Awesome - Thanks for the pics - that really helps.
    Boynton Beach, FL
    Flashlight & Letherman Tool
    2014 ST-L
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    I carry a tire plug kit and compressor. Also a butane soldering iron and some solder. Has come in handy several times on other bikes. I've spliced an SAE connector on the compressor that plugs into the SAE in my frunk.
    1976 RD400c
    Sep 2020
    Ontario, Canada
    From Sportster Doc's post
    That installation on the rear fender looks so clean and purposeful, absolutely functional. Well done!
    Mar 2021
    Arizona high country
    small first aid kit.
    Tooth brush to get the bugs off your teeth.
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    A spellchecker? <G>
    Some nice suggestions though. I'd at least pack some hobby wire, duck tape, a bungie net, and a tire repair kit.
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    Mar 2021
    Michigan
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Remember it gets hot in there! Make sure whatever you put in it can withstand the heat. I put aluminum insulating tape on the exterior similar to what Slingmods sells, but I bought a roll for about $10 that worked perfectly.
    Jun 2021
    Mass, USA
    What kind of fender bag is that?
    May 2021
    Nevada
    Daily driving city or to and from work not much, small tool kit is about all, long trip as much necessities as possible. Tools, wire, tape, first aid, tire kit, extra water (even if hot it's still water) rain gear and what ever else I can think of and fit in the side bags for the trip. Frunk/trunk gets the travel bags and needed items for over night stay.
    2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
    Jan 2019
    Hunter Valley NSW Australia
    Mine is permanently stocked with
    • Tyre Gauge
    • Tyre Valve extension
    • Visor Wipes
    • Micro Fibre cloth
    • Owners Manual (only because I'd forget it when I go for a service, and at 200KMs to get there, I cant just drop back to get it)
    • Rainex and open weave soft cloth for it in Ziplock bag
    • Intercom Cheat Sheet laminated (for when it goes into some mode and need a PhD to get it back to normal)
    • Shopping bag (for that run to the supermarket or wet/muddy/dirty clothes)
    • 2 x plasticised cable bike locks for when we travel to attach helmets to pillion hand grips
    2017 RTL
    2017 RTL , White
    Jan 2021
    Long Island, NY
    I put the stuff from my pockets in the frunk.. I bought a motorcycle license plate stash box that goes where the rear license plate goes and keep my registration, insurance, tire plug kit, apple airtag, co2 cartridge (to fill tire) in it.
    2021 Sea to Sky
    2020 600 , gloss black
Tags for this Thread
