Results 1 to 12 of 12
    Jun 2019
    Pilot Mountain, NC
    Default Fuses - does anyone have sources for Can-Am fuses??
    A SpyderLover on Face Book suggested to my wife (2019 F3T) that it would be a good idea to carry an assortment of spare fuses in her bike and mine (2017 RTL). The fuses in my bike do not resemble anything I have seen in auto supply stores. Does anyone have a source for CanAm Spyder fuses?
    Jul 2015
    Dorr, michigan
    Both of my Spyders use a standard automotive fuse available at autozone.
    https://www.autozone.com/electrical-...ece/422404_0_0
    2020 RT Limited , Petrol Blue
    Idaho
    Quote Originally Posted by JO2L View Post
    I think you need to look closer. The Spyder fuses are all standard automotive fuses.
    2014 Copper RTS
    Sep 2017
    INDIANA, USA
    Default Fuses
    So far, most fuses for Spyders have been an 'automotive type'. Check yours and let us know if they are different. Post a picture of 'what you are looking at' may help us. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Oct 2015
    Lynden, WA
    The fuses are very small but definitely automotive.
    I bought spare fuses at Napa.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Do you mean these fuses they are called J Case fuses there are 2 lengths available
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Apr 2021
    Ky
    Quote Originally Posted by eddieshep999 View Post
    Those are expensive.
    Apr 2019
    Florida Swamp
    2019 F3-S , Black & Silver
    Nov 2008
    las vegas, nv
    Those j case fuses are $5 a piece at auto parts store.
    I bought assorted 30 pack from Amazon for $16.
    I don’t think there are too big a difference and one I did use already is still going.
    6 states down 42 states to go
    Jun 2019
    Pilot Mountain, NC
    Thanks for the link. Bought one set for each Spyder. Also, discovered that the last person looking into this apparently broke into the cover box and it fell off into my hand.
    Member Gekko's Avatar
    May 2019
    Huntington Beach, California, USA
    Default Spyder RT fuse dimensions
    I just went to my Spyder and took physical measurements of my fuses.
    The JCASE type appear to be the longer ones at 27 mm long.
    The blade type measurements match the "Mini fuse" size as shown in the image from Wikipedia.
    FYI, there are 5 spare blade type fuses mounted inside the inner cover of each of the two fuse boxes. They are 5, 10, 15, 20, and 25 amps. That's what I found in my 2019 RT; I don't know if yours has the same.
    Gekko (Larry)
    2019 Spyder RT SE6
    BRP Driver Backrest [219400679]
    Can-Am Spyder RT Magnetic Side View Mirror Mounting System (2010-19) [SM-4018, TAC Designs at SlingMods.com]
    Centramatic Wheel Balancers [MCAS400-410]
    Grab On Grips Grip Covers [FBA_MC402]
    Hopnel Cargo Organizer Nets For Can-Am Spyder RT [41-156]
    Hopnel Four Piece Luggage Set For Can Am Spyder RT [HCTL + HCSL]
    Marinco Power Products Pro Receptacle (in frunk) [12VRCTT.OEM]
    AmazonBasics Dual-Port USB Car Charger Adapter [CLA-2U5480_white]
    RAM 1" Ball Compatible Dash Mount (Black Powder Coated) [RT-RAM3]
    Various RAM mount components, phone mount, camera mount...
    2019 Can-Am Spyder RT / RT Limited Series Repair and Maintenance Manual Master Collection [Best Shop Manuals 180317]
    Show Chrome 41-180 Shorty Antenna
