Results 1 to 11 of 11
    Apr 2020
    Lebanon ohio
    Default How is the side bag latch held in?
    On a 2020RTL does anyone know how the latch is held in place on the side bag the latch I I talking about is the whole asembly it is popped out case. Thanks
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    It is a double latch about 4" long. Held in with 2 screws. I am putting a flashing module on my RTL this after noon and will take a picture of the assembly for you when I have it exposed.
    This video from sling mods (if the link works) shows how to expose the latch assembly.
    https://www.slingmods.com/canam-spyd...cled?vehicle=1
    2021 RTL Chrome Deep Marsala
    HELI Bars
    Garmin Zumo XT
    USB power port
    Front fender lights & Sequential turn signals
    Front LED Auxiliary light
    Flashing brake module TricLED
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    2021 RT Limited , Marsala Red
    Aug 2019
    Maine
    I just read your post again? Are you talking about the latch or the release handle ?
    HELI Bars
    Garmin Zumo XT
    USB power port
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    Apr 2020
    Lebanon ohio
    It is the whole assembly that is on the side luggage the part that hold the lever it has a lip around it that should be flush.against the bag. THANKS
    Aug 2019
    Maine
    Longtimer,
    I have the back of mine all apart. The release handle is very hard to see what all holds it there. The trim panel slides into the handle and the handle stays in place when the trim panel is removed. I won't be putting mine back together until tomorrow after work. I can take pictures, but would help if I knew what yours looking for or maybe what yours has done. I think the lock cylinder itself has a lot to do with keeping it all together. Is your handle loose and flopping around or just the trim panel not in place?
    HELI Bars
    Garmin Zumo XT
    USB power port
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    Apr 2020
    Lebanon ohio
    Quote Originally Posted by Longtimer View Post
    It is the.assembly that holds the lever it is not flush with the bag the lever works fine to open the bag the assembly is not lose or floping around it use to be flush against the bag something moved or came lose I look up from the bottom but can not get a good view. THANKS
    Aug 2019
    Maine
    sounds like the trim panel came out of the grove around the handle. Here is a picture of the panel (I'm holding it for reference). The panel when installed goes into that grove around the handle.
    HELI Bars
    Garmin Zumo XT
    USB power port
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    Aug 2019
    Maine
    Her's a picture of the whole panel removed and the side of the Spyder without the panel.
    HELI Bars
    Garmin Zumo XT
    USB power port
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    Apr 2020
    Lebanon ohio
    Thanks papa 103 the panel was not slide in the slots I just losen the screws and lower bolt on panel and got it slide in place Thanks for your help one other thing is the screw s that hold the panel on are they like a push pin but with just a screw instead of a pin because they do not feel like they tighten up very tight. ThanksI
    Aug 2019
    Maine
    There are 4 real screws, 2 behind the strut and 2 on the top face. The 4 plastic screws are really just push pins. They screw out about 1/4" then I took needle nose pliers and just pulled them out. Glad it helped.
    HELI Bars
    Garmin Zumo XT
    USB power port
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    Aug 2020
    Creal Springs, Illinois
    Got the same issue. Need to take a closer look.
