Results 1 to 5 of 5
    Oct 2016
    Sebring, FL
    Default Any feedback/comments on Driver Foot Board Risers from users?
    Any comments on the 2020 RTL foot board risers from those that have done the install?
    Feb 2020
    Minnesota,USA
    They work Great on my 2020RTL. Stable, easy install, and makes brake pedal easier access. Wife can get on easier and I feel more comfortable with these risers and the two inch handlebar riser from Lamonster. Best 2 mods on my ride!
    Oct 2016
    Sebring, FL
    Thanks Knizar, on the cusp of pulling the trigger on this.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    I did it. The Lamonster kit was (as usual) well engineered and very well made. The installation was easy and quick. The hardest part is supporting the weight of the floorboards while keeping the holes aligned as you insert the bolts. The difference is rather subtle, but noticeable. However, I do think you need to also raise the brake pedal too. I did it myself with parts I had laying about. I raised it about 1/2" and that was good enough for me. Others might want to purchase the brake pedal riser kit also sold by Lamonster, which raises the pedal even further.
    2020 RTL SE6
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Quote Originally Posted by KX5062 View Post
    KX5062 pretty much nailed it. Two additional comments: I can now use the whole floorboard (front to rear); Seat pressure on my thighs is reduced. I have Lamonster's brake pedal riser, and in combination with the boards, I have much better control of the brakes.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
