Ryker oil change & wheel ramps
Hi all,
Is it possible to do a Ryker oil change by just rolling the front wheels up on ramps... or should I also raise the rear and level it out?
Thanks!
Raise the front and back. You want it level.
Back up on the wheel ramps and jack one of the side rear jack points in the manual.
Sea Doo GTI-SE 90 Jet Ski!!
Yes, that is what I did today for my Ryker's first oil change. It worked perfect
23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
2020 900 , NGK 4218 iridium CR8EIX Matte black
Actually changed my ‘19 Ryker 600 oil today. Wanted to get familiar with how to lift the bike... so used a jack and stands. Wasn’t hard at all. May return the unused plastic ramps and just go that route if it ever needs lifted.
