Results 1 to 8 of 8
    Active Member CarlWms's Avatar
    Oct 2014
    Colorado
    Default ZUMO 590 LM (Lifetime Maps) Garmin GPS Plus 3 Different Mounts
    {SOLD} Zumo 590 LM Garmin GPS comes with all software and maps updated. The Zumo 590 LM can be transferred to your account so you can update it in the future.
    Zumo 590 LM comes with;
    1. Protective Zippered Carrying Case
    2. Download Cable
    3. Owner’s Manual
    4. Quick Start Manual
    5. Installation Instructions
    6. Zumo 590 LM Motorcycle Wiring Harness Specification Sheet
    Three (3) Different GPS Mounts;
    1. OEM Bike Mounting Bracket, longer bike mounting bolts, Can Am OEM Wiring Harness removed from a Spyder RT Limited, plastic Protective Cover and Weather Resistant Rubber Protective Cover.
    2. Automotive Mount which includes Suction Bracket, Zumo Mounting Bracket with 12 vDC Cigarette Lighter Power Plug and power cable.
    3. Ram Mount Zumo Bracket with 3 foot power cord and plastic Protective Cover.
    I replaced the Zumo 590 LM with a Garmin Zumo XT unit. None of the Zumo 590 LM mounting brackets and power cables are compatible with the Zumo XT. The Zumo 590 LM, three mounting brackets and cables are $290 shipped to lower 48 states.
    Apr 2021
    RI
    Good morning. Does the motorcycle mount fit a 2021 rt limited. Thanks
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Gasman1976 View Post
    The whole set up will work on the 2021 RT. On the power cord, you'll only use the power end and you'll have to cut the plug and play end off. The other three wires will just be rolled up and zip tied out of the way. The mounting bracket looks as if it'll fit on the handlebars. Not sure if it came off of an F3. That would be my only concern.
    I hade the same set up on my 2020 RTL until I upgraded to an XT.
    2020 RT Limited , Chalk
    Apr 2021
    RI
    Quote Originally Posted by Copperman View Post
    Thanks
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    PM Sent
    2022 RT Limited , Silver w/ Black and Purple accents
    Oct 2014
    Colorado
    Sorry, I do not know. Maybe your dealer can answer your question.
    Dec 2020
    Baytown, Tx
    You have mail.
    Dec 2013
    PM sent - please send 'Read Receipt' & update Thread.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
