Ryker Accessory Connections
Hi all. Does the Ryker have accessory connection points like the F3 has?
Two USB points inside "frunk".
Spyder F3-S Special Series my traveling ride
Ryker Rally modified for dual sport duty
Honda Grom heavily modified for dual sport duty
Ducati Scrambler Icon Dark my other traveling ride
Also has a spare two wire keyed power supply for accessories underneath the left light color panel. I used this to power two USB power ports mounted on the handlebar for my phone & dash cam, GPS and such.
2020 Can Am Ryker Rally Sport Touring Edition
What light color panel are you referring to?
Greg Kamer
USAF, 20 years, retired
2018 Can Am Spyder RT-Limited
The left removable panel by the headlight.
Yes it the interchangeable panels that allows you to change out to different colors. If you remove the left one, you will see a wire lead plugged in. its towards the gas tank. its actually plugged into nothing, its just a holder for that accessory plug. Whats nice about it is that its power is shut off when you turn the motor off, so no chance of accidentally leaving something plugged it that power source and killing the battery. Slingmods sells the male plug that plugs into it.
