Results 1 to 5 of 5
    May 2019
    Manhattan
    Default My 2012 can am rs starts up then dies.
    Hello everyone,
    I been away for a while had double knee surgery. Rocvery has been tough.
    Its starts and then shuts down 30 sec later by its self won't start unless I disconnect the battery. Has anyone heard of this before.
    Thank you
    Jue
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Need more info, Juejue, How old is the fuel? Did you hook up a tender to the battery? I think it's a fuelproblem, cause it starts and runs for half a minute, clogged fuelfilter comes to mind, injectors fouled up, try to put some stabilizer in the tank.
    First drain the tank, put in fresh gas, try again, if problem is still there you need to use an injector cleaner, and install a new filter. (use injectorcleaner wisely, read the instructions from the vendor, cause that cleaner burns hotter then fuel)
    Just solve one problem at the time, bike's that are sitting for a long time, become a bit quirky. Do you see a faultcode?
    Many more things, can point to this particular issue, even critters in the airfilter, are somtimes seen.
    Let us know, if you solved the issue..
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    May 2019
    Manhattan
    Quote Originally Posted by Piratezz View Post
    Thank you for your reply I will check all these things and I will get back to you.
    Juejue
    Bossier LoUiSiAna
    Codes? Before disconnecting battery
    SoFlo
    Since it is a V twin, and they are known to consume oil, ensure the oil level is 100% correct.
    Not sure why you are needing to disconnect the battery, possibly to reset a low oil code, but truly do not know.
    If it starts and runs, without running poorly, fuel is likely ok.
    The other item may be a failed vacuum hose.
    Those would be my own first checks.
