Results 1 to 7 of 7
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default How the throttle response unit works and WHY IT HELPS!!!!!
    For the last time I am trying to explain this topic. I am aware that it is my mistkae that I was not very clear in the previous videos, so here is very simple explanation how it works on Can Am Spyder and RYKERs
    You can get the PEDALBOX right over here:
    https://www.martinthevlogger.com/shop
    Sep 2020
    Middletown, NJ
    Thanks for all your informative videos. My hearing is not that good and I struggle with the echo in your recent posts. Is it possible for you to use a lapel mike or something closer to you? The info is very helpful when I can more clearly hear it.
    Thanks again for your contributions!
    2020 RT base , Chalk White
    Mar 2015
    very good point.. I am struggling a lot with audio set up these days.
    1 - my studio is very big/tall and open and it drives me nuts
    2 - if you look closer i have the mic,. but for whatever reason i cannot find the right set up. This time it was too quite so i had to use 2 layers of audio to be loud enough.. gopro and mic.. and then it is ruined..
    but i will work on it, coz good sound is the must!!!!
    3 - can you please tell me if this video/spund is better for you, please???
    Quote Originally Posted by RayBJ View Post
    Sep 2020
    Middletown, NJ
    That audio is excellent! Very understandable.
    Mar 2015
    thank you.. ok, so i know what to do now.
    its the thing that I was also lazy with Q&A episodes and i have recorded audio with my camera only.
    I will not do it anymore.
    I will play with mic to be at least as good as on this video i have asked you about.
    again thank you very much for telling me. sometimes I miss these things...
    martin
    Apr 2021
    Ky
    Thanks Martin, now I understand!
    Mar 2015
    thank you for letting me know
    Quote Originally Posted by Hoginedgewood View Post
