Results 1 to 25 of 25
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default can't add a new location on map
    Try as I may, I can't get a new location (mine) to post on the map. It always ends up only showing 3 Washington locations and none added new.
    Please help - What am I missing in instructions? Basic location is Tenino, Wa. which I can find on the map but "adding" doesn't keep it when I go out and back in.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Sep 2020
    Middletown, NJ
    ditto
    2020 RT base , Chalk White
    Server Admin AnthonyG's Avatar
    mi
    Did you get the popup to add a new location to the map?
    Either right click or double tap when youre on the map
    2018 F3 , Red
    Sep 2020
    Middletown, NJ
    Tried Chrome and Edge. Neither work. Not using ad or popup blocker. Double click zooms in and right click does nothing in both browsers. When I hold left button for a few seconds the popup appears but when filled in and clicked on Save Marker, nothing happens.
    Mar 2021
    Arizona high country
    Quote Originally Posted by RayBJ View Post
    Same problem for me. I also tried Safari
    Nov 2015
    Myerstown, Pennsylvania
    Same for me. I can get the popup on the screen for a marker by holding the right button but the marker won't save.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Active Member Coastie's Avatar
    Mar 2021
    Loudon County, Tennessee
    Same problem here. Glad to know it is not just my web browser or Linux.
    Coastie
    Spider F3-S SS 2021
    H-D Tri Glide 2012
    2021 F3-S SS , Black, gray, & orange
    Innnnterrresting?? You (& others) have seemingly done the right things, but there's obviously no go?!? Yet we've had another member successfull add their location today - after this thread was initially started?!?
    Maybe you're just facing the wrong way, possibly cos you're on the wrong side of the country?!?
    Mar 2021
    ... Maybe you're just facing the wrong way, possibly cos you're on the wrong side of the country?!?
    Maybe the wrong continent or hemisphere?
    Coastie
    Spider F3-S SS 2021
    H-D Tri Glide 2012
    mi
    Double tap is for a phone, i didnt say double click, double click on a computer is for zoom.
    Right click on a computer pops up the add marker window.
    Quote Originally Posted by rjinaz86323 View Post
    Quote Originally Posted by SteveLaoyster View Post
    Quote Originally Posted by Coastie View Post
    You shouldnt have to hold the right click, just one right click pops up the window.
    I tested the system on safari in linux & windows, chrome, ff, they all worked at that time.
    A popup blocker shouldnt stop that window either.
    Is there any error when you click & try to save?
    2018 F3 , Red
    Mar 2021
    No error. Just doesn't do anything
    Sep 2014
    tenino, wa
    Yes, and I did
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Sep 2014
    tenino, wa
    agree - even this AM
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Sep 2020
    Middletown, NJ
    Since the single click did nothing, I tried double click (and every other combo of left, right, single, double, click&hold, etc.. No errors when box comes on and attempt to save after filling in info. Nothing happens, box remains in view and no marker is saved.
    mi
    Quote Originally Posted by teninospyder View Post
    ditto
    I tested on my iphone mini, safari & chrome no longer work.
    I do not have an ipad or apple computer to test with.
    To the posters with issues, please list what phone/computer/OS/browser youre normally using.
    2018 F3 , Red
    Mar 2021
    Mac OS Big Sur
    Ver. 11.2.3
    Safari Ver. 14.0.3
    Also tried with Chrome and still no joy
    Sep 2020
    Middletown, NJ
    Win 10 Home OS Build 19041.928
    Chrome Version 89.0.4389.128 (Official Build) (64-bit)
    Mar 2021
    Quote Originally Posted by AnthonyG View Post
    ... To the posters with issues, please list what phone/computer/OS/browser youre normally using.
    PCLinuxOS and Firefox 88.0
    Coastie
    Spider F3-S SS 2021
    H-D Tri Glide 2012
    Jul 2021
    IL
    I also am unable to mark the map. Right click does nothing.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Quote Originally Posted by vito1943 View Post
    See AnthonyG's post as quoted above - what are you using?
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    So I am pretty much newbie to the workings of this site. I thought the "map" was for members to mark their location. After reading THIS thread I clicked on the map and was able to put a marker on it with my screen name and location - but - the marker itself is about 150 miles from my actual location. I can't make the marker move to my actual location by editing the info or dragging it and it says I do not have permission to delete it.
    Evidently with my input of the marker it put a thread out here that showed I had input the marker.
    That thread is called Pooch, Kerrville TX.
    Then...I get a sarcastic response that indicated it was somewhat useless for me to have input the marker since I did not have any tools, etc to provide.
    I apologized for doing so in that thread and apologize for doing so in this thread.
    Moderators, please just delete the marker and be done with it. Thanks.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Pooch View Post
    Sorry, I tried to avoid sounding sarcastic or judgmental. Ironically I was just about decided to add my own marker when your thread appeared.
    2014 RTL Platinum
    I'm sorry Pooch, as I replied in your Map Marker thread, that sarcastic post (since removed) was completely uncalled for & highly inappropriate! . The Member Map IS intended as a 'Member Map', the extra info is just there for those people/instances where a member is in a position to & might be able to offer more in the way of tools, accom, workshop etc - but at its simplest, the map is really intended just to let others know where you are!
    Btw, it probably pays to be juust a little vague in telling the World via the Internet & all its readers/users/abusers EXACTLY where you are located for a whole shed load of perfectly valid reasons; but I hafta agree, 150 miles is probably a bit too vague! I don't know exactly how to resolve/move your marker, but I'll pass it on & see what we can do to fix it!
    Jul 2021
    IL
    Is this being fixed? I tried again today. Right click does nothing.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Member 65cabriolet's Avatar
    Sep 2019
    Brighton, CO
    I've got a marker on the map (put it there a long time ago) that I've changed to "Mistake" because it's in the wrong place, should be up by Seaweed but I can't move it or delete it.
    2007 V Star Classic - sold
    2012 Spyder RTS SE5 - sold
    2020 Indian 100th Anniversary Scout
    2021 Spyder RT LTD
