Results 1 to 4 of 4
Hybrid View
    Jul 2019
    australia
    Default 2008 gs broken down
    have broken down , pulled up at shops with ever thing working ok ,when went to restart screen came on , hit modem button all ok, hit starter and screen when blank with starter not making a sound couple mins later after trying the key couple of times screen lit up , hit modem button all ok hit start and blank screen and blank since (couple of days after trailering it home) battery read 12.6 volts but put on trickle charge anyway for 6 hrs (thinking wouldnt start if battery but might lite up screen ) found from day of break down no horn/indicators etc but hazard lights work very bright .. all fuses seem to be ok , been told 2 circuits off ign switch , one mains and 1 for hazard lights .. any and all ideas would be appriciated
    Bossier LoUiSiAna
    Age of battery? Double check battery connections are clean & tight. Load test the battery Is advised, not just a trickle charge.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default 2008-gs-broken-down
    My vote would also go to faulty battery or bad connections @ battery terminals
    Al in Kazoo
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Make sure all the relays are seated, along with all the other suggestions here.
    john
