Results 1 to 8 of 8
    Active Member Rocketman 2012's Avatar
    Oct 2015
    Carthage, Missouri 64836
    Default 2021 RT display changing fm full color to light gray - what's going on?!
    Sometimes my Screen is full color and then as I glance at it again, it is a light gray color???? I wonder what is going on?
    Sam
    2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
    Feb 2017
    Sam, we discovered the same situation with our 2021 Sea to Sky. Here's how to solve the issue. Pull the "trigger" on the front of the left switch module to access all the settings available. Then, with the joy stick, tap down to reach the gear wheel icon the very last icon. Tap right to select "Display," then tap "Mode" the select "Dark." Yours is apparently set to "Automatic" as our was and that setting will change the display depending on ambient light. Change the setting to "Dark" and you'll have the "full color" instrument panel regardless of the ambient light conditions - bright sun, clouds and overcast, or pitch black night. Hope this helps.
    Oct 2015
    Thank you so much my Friend! I thought it was probably going bad!!!!
    Sam
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    I actually like the display change, even does this on my Tesla auto as well, but good to know I can manually alter the settings. Heck even my 2010 RT had this feature
    Jan 2021
    Oklahoma City
    My 2021 does the same thing, it does seem a little over sensitive but I leave it in automatic mode so it will change at night although I don’t know why since I very rarely ride at night!
    Mar 2021
    TX
    One can also change the light intensity. Mine was on the dimmest setting which made it extremely difficult to read the gauges. Changed the setting to mid point. Now it is as it should be, day or night.
    Durham,Maine
    I like that item on mine, I don't like all that light in my eye's when I am night riding.
    2012 RTL , Pearl
    Mar 2021
    TX
    I agree. Personally, now that I've increased the multi colored background lighting to midpoint, I much prefer that to the daytime screen.
