Results 1 to 10 of 10
    Dec 2011
    Chula Vista, Ca
    Default Looking for a VSS module 219800097
    Hey Riders,
    I have a 2010 RT that is fun to ride but not so fun to repair sometimes. It's now showing that the VSS module part number 219800097 needs to be replaced, looks like it's the same part through 2012.
    anybody out there know of someone parting out an RT or a good salvage yard that handles Spyders?
    Troublemaker
    Quote Originally Posted by Troublemaker View Post
    Hey Riders,
    Troublemaker
    Unless you are ABSOLUTELY SURE ( by testing it with a device, not a Spyder code ) ./... I would take key from ignition dis-connect BOTH leads to the Battery and touch them together .... wait about 5-10 minutes and then reconnect ( using Star washers on terminals ) ..... this will allow a complete RE_BOOT of the computers ..... then start it & see if the CODE dis-appears .....good luck ....Mike
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Edit:Just ignore my response. I totally mis-read the OP's message.
    Your better bet, since you have a 2010, is find someone with BUDS and the Megatech license and just get DSS turned off. Then you never have to be worried about being stranded with a bike that won't start.
    Last edited by Trbayth; 04-13-2021 at 08:46 AM. Reason: Completely blew the response
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Quote Originally Posted by Trbayth View Post
    " DSS " ????? He said " VSS " .... did you mean " DESS " module ..... Mike
    Jun 2014
    Schenevus NY
    Wow, did I blow that response. Just ignore me while I go sit in the corner
    Trb-- (Roger)
    Aug 2007
    Greeneville, TN
    Hey Riders,
    Troublemaker
    I can't help you with a used component. But if you find that you, in fact, need one. I can probably save you some on a new one. Let me know if I can help. Hopefully, you find that you don't need a new unit. I would be very sure before you pull the trigger on another one. You can't return electrical components.
    Jun 2015
    New Columbia PA
    I feel your pain. Just had mine replaced in my 2011. $1800.00
    Dec 2011
    Chula Vista, Ca
    Thanks Ron if it comes to replacement I'll keep you in mind.
    Steve
    Mar 2019
    NEBRASKA
    Steve did you fix this isssue? I know this was posted in April
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Dec 2013
    No recent action or replies, so I've closed the thread as inactive. If you still want it live Troublemaker, please PM me.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
