Missing plastic screw in trunk area
Hello fellow spyder lovers! I am missing one of the plastic screws in the trunk lid area and have having a real hard time finding the part number (or even if it's the origional/correct screw).
Does anyone have any idea what the part number is?
A screw or a push rivet? Amazon.com has both.
It's a plastic screw rivet (1/4 turn unlocks it).
Try your Ace Hardware. Mine has them.
What year is your Spyder? My 2014 RTS has plastic push pin rivets there like those used all over the Spyder. I think someone replaced yours with whatever they had on hand when they lost the originals.
It's a 2010 RTS. I'm guessing you're probably right, they got replaced with whatever was around. Are those typically the same toughlock ones that are used for the rest of the body panels?
Thanks Gwolf and RICZ, I'll check those out.
