Page 4 of 4 FirstFirst 1234
Results 76 to 84 of 84
  1. #76
    Oct 2020
    Arizona
    Quote Originally Posted by carsong View Post
    If I run the front wheels up a set of ramps to the back of my pickup bed, will that be high enough to do the install? I figure there would be height and angle. Yes?
    Be sure to strap down the ramps. My friends pinned into the hauler bed.
  2. #77
    Aug 2007
    Greeneville, TN
    Yes, this method works very well and many use it. Just remember to strap the ramps to the truck, as mentioned. And I also recommend chalking or blocking the rear wheel. Overkill doesn't hurt.
  3. #78
    May 2019
    Port St. Lucie, Florida
    Quote Originally Posted by Snoking1127 View Post
    Do you mean the ramps rocked in, instead of staying flat?
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
  4. #79
    Apr 2021
    FL
    What kind of jack are you using and ramps I’m looking for something decent but not too pricey?
  5. #80
    May 2019
    I just bought a set of used ramps, to do the job. I don't plan to lift the rear.
    -Carsong
    2018 F3t
  6. #81
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Quote Originally Posted by AZCanAm View Post
    In terms of the spacers, it was easy for me (not bragging). You push the screw in partly, then put the spacer on by back it up enough to get spacer positioned, then continue pushing the screw all the way thru.
    I can't remember if it is the 10mm or the 13mm, but you will need two of them because otherwise the nut on the other side will spin. If I remember correctly, it was the shields near your foot that needs two wrenches. Personally I used a rachet and a wrench of the same size.
    The kit does come with "super glue" if you want to set the spacers in place first.
    Installed the BajaRon swaybar and links yesterday. I removed old links and installed new links with cycle on the ground. I had purchased a 5/16" dowel on the weekend, but my wife was away with the car, and that is where I left the dowel. There was no super glue in my kit, and my wife's e6000 glue had hardened up. I used a nylon zip tie to thread the upper link assembly through and was able to get the bolt through as I slowly pulled out the zip tie. Two 13 mm wrenches used for fasteners, one was a ratchet wrench.
    Time for a ride later today.
    Rick
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
  7. #82
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    You will be happy with this purchase for sure. Welcome to a safer more fun ride. Nice job on the install. let us know what you think when you get a chance.
  8. #83
    Jul 2019
    Very pleased with the BajaRon swaybar. There is a number of country roads around here with twisties, and the bike clung to the curves better. I also took in on the highway. I used to slow down on one particular curve, and now, no need. I would have ridden longer this afternoon, but hot outside. Looking forward to getting out again!
    I had a technical question, and Ron assisted me. I also called today about another technical matter, and spoke with Daniel, who also was of great help. Great company to do business with.
    Rick
    Rick
    2019 F3 base
    BajaRon swaybar
    Hopnel mini bra
    Madstad windshield
  9. #84
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    Just got the anti-sway bar installed and I’m pleased as punch. Much more stable and confident in the curves and not so affected by crosswinds.
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Ultimate Floorboards
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
