Results 1 to 22 of 22
    Active Member Bruiser37's Avatar
    Jun 2016
    Tucson Arizona
    Default 2021 Spyder RTL headlights - BRP Blunder!
    RT 2021 Spyder Low beam projects wide V pattern on road ahead. Center of beam projects downward for approximately 30 to 40 yards for averge width of a two lane road beyond that is a black hole and you see absolutely nothing 40 to 50 yards beyond road head... a very dangerous condition to ride more than 45 MPH at night. Upper legs of V pattern lights up both sides of two lane road very well out to about 50 to 65 yards. Completely ass backward from way it should be for safe ride after dark. High beam lights up center of road for safe riding at higher speeds. High beam must be used 100 percent of the time for all after dark riding conditions. But Then all on coming traffic ios flashing reminder to turn off your high beams... another ass backward condition you are forced to live with for safe riding after dark.
    I have owned several single headlight motorcycle brands dating back from mid 50's to modern motorcycle brands with dual LED hedlights. 2020 -2021 Can Am RT spyder headlights are worse than all of them and there is no third party replacement hedlights available to correct this egregious BRP engineering blunder.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Feb 2020
    N. Wilkesboro, NC
    Everything changes once you add the Auxiliary light.
    Feb 2019
    Portland, Oregon
    Here's what a pair of auxiliary lights can do.
    Quote Originally Posted by Bruiser37 View Post
    LED headlights are from " third " party sellers..... and your headlights may not be focused properly ..... good luck .... Mike
    Sep 2017
    Durham,Maine
    Mike may have some thing here, if they are LED, they may not be focused!! That would be tossing a strange pattern to the ground.
    2012 RTL , Pearl
    Oct 2020
    KS
    The manual on my "21 RT has a page on focusing and adjusting the lights.
    Feb 2017
    Quote Originally Posted by milryder View Post
    Good point. There is no guarantee that the lights are "correctly" aligned when a Spyder leaves the factory. Guess that's why there is the ability to adjust them, yes, no?
    Dec 2013
    Quote Originally Posted by Arion View Post
    Nah.. Yeah.... RIGHT??
    Sorry, but I just hadta! She made me do it!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Apr 2016
    Albany NY
    Mine were horrible from the factory had to adjust them they are great now.
    Apr 2015
    Grand Forks, ND
    What did you use as abase line to adjust the head lights?
    Jim
    Idaho
    Check that to be sure. The 2020 & 2021 parts catalog shows the headlights as a single assembly with no separate bulb. The specifications list in the operator's guide lists the headlight simply as LED. The parts diagram looks like the bulb can be removed, which only makes sense, but what would the replacement be? It looks like they come from the factory with LED headlights.
    There are two adjustments on the '20 & '21 headlights, up/down and left/right. There are two bulbs in each light. The outer is the only one on for low beam.
    So the '20+ headlights are altogether different from what we're used to dealing with.
    2014 Copper RTS
    Feb 2019
    Portland, Oregon
    On the subject of headlights....I am in the process of switching my F3L to LEDs. Each headlight is tethered by an adjustment cable that prevents them from being completely removed. I was able to JUST switch out the left headlight, but there is not enough space to do the right one. Ironically, Lamonster has an excellent video, but only shows changing the bulb on the left headlight and not the right.
    + What did you do access the back of the right headlight?
    + There is an easy to remove clip at the cable's console end - if I undo that, how difficult is it to get it back into place?
    + Does the cable detach at the headlight?
    TIA
    Idaho
    TIA
    On the RT the headlight adjusting cable is anchored to the fiber body brace under the upper panel with an easily removable nut. The cable can be pulled out to enable taking the headlight completely out of the Spyder. Feeding the cable back to the brace isn't a great challenge. I would think the situation would be same with the F3.
    2014 Copper RTS
    Thanks, glad to see BRP is getting up to speed on the new products ........... Mike
    Apr 2016
    Albany NY
    I have the front of the bike at 25 ft away from the garage door. Low beams on. The top cut off line which looks yellow in the picture is 38in off the ground.
    Feb 2019
    Portland, Oregon
    My method of adjusting headlights is to go out at night and do an "aim and ride" until they are lighting the road where I want them to. I start on flat pavement and a wall that I can do the initial aiming on.
    Jun 2016
    Tucson Arizona
    Thanks your suggestion works
    Jan 2019
    Hunter Valley NSW Australia
    I feel your pain. I have a '17RTL and here in the land down under our headlights are your Foglights. They are about as effective as a match on a tornado. I note too BRRRRP says the Spyder should not be ridden at night
    2017 RTL
    2017 RTL , White
    Jun 2016
    Tucson Arizona
    Quote Originally Posted by TIMMB View Post
    Projecting my new 2021 RTL Spyder LED low light beam on garage wall target calculated right triangle (Pythagoras’ Theorem) headlight alignment horizontal center of bright line in front of Spyder on dark road is exactly 22.8 yards. Low beam headlights are looking down at road exactly 2.23 degree angle. Don’t ride more than 40-45 mph on a dark country road with low beam or you’ll never see that large pot hole (worse yet a black cow) ahead in time to avoid. �� �� That’s exactly why you can’t see our RTL low beam headlights in daylight. Truth is if headlights were properly aligned you would easily see RTL on low beam in daylight and high beam at night would be more efficient. Those lower BRP factory and third party RT Spyder LED light bars are usless for night riding.
    Jun 2016
    Tucson Arizona
    Default 2020-21 RT Spyder LED headlight horizontal adjustment
    I have concluded from my recent experience 2020 - 21 RT Spyder LED headlight horizontal angle -2.23 degrees must be reset to zero degree for optimum, maximum low and high beam safe riding operation. I moved glove box to side and with fingers located right & left hand horizontal allen screw alignment adjustments according to owners guide instruction. Unless your hand size is that of a 10 year old child forget adjusting RT Spyder LED headlights through glove box, run 100 percent on high beam and avoid riding in dark.
    No wonder they come assembled default from manufacturing without adjustment… that’s an owners option.
    Also noted Canadian RT LED Spyder headlights are screw driver adjustments located in Right & left hand mirrors… so convenient.
    Aug 2015
    NW Iowa
    how does the mirror trim piece come off? I'd hate to break it!
    Now
    2021 Sea2Sky
    Former
    2015 F3-S
    Aug 2015
    NW Iowa
    nevermind I finally got it! Now I hope the aim is true!
    Now
    2021 Sea2Sky
    Former
    2015 F3-S
