What's the Best Phone Holder for Lamonster's Spyder Cuff?
After three years of no cup holder or phone holder, I don't want to go another summer without the Lamonster Spyder Cuff for my RT. When it comes to the phone holder, which product have people had the best luck as an add-on?
- Lamonster RT Spyder Cuff with Lamonster Phone Phang Holder
- Lamonster RT Spyder Cuff with Lamonster Approved Phone Holder
- Lamonster RT Spyder Cuff with Large X-Grip
- Lamonster RT Spyder Cuff with [Fill in the Blank] Phone Holder
Along the same lines, I'd also like to know if anybody had their phone slip from a holder and which holder this was?
Thanks ahead of time for your input!
2017 Spyder RT Limited - Champagne Metallic Chrome
- Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
2021 Spyder RT Limited - Deep Marsala Metallic Dark
- Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
I really like the tracform holder better. I have lamomsters cuff with ball and the tracform I bought from motorcycledave. The ram mount phone holder was right on top of my power button and turned my phone off. Also wobbly. Dave had the best price on it. Again this clips on lamonsters cuff and is a much cleaner looking unit. No need for the rubber web, your phone won’t move with this. The ram mount yes use the rubber web. It was wobbly. Here’s their link. https://www.tackform.com/collections...or-1-inch-ball.
I like the Tacform best also. I had used the X-Grip first, and it just never seemed secure enough without the rubber band holder. You can insert and remove your phone with one hand with the Tacform. And it holds rock solid with no worry of it falling out. I mounted it on the Lamonster RT Spyder Cuff also.
2022 Spyder RT Limited Sea to Sky Mystery Blue
This is what I use with Lamonster cuff. I had the X-grip before but wasn't comfortable with grip w/o hooking the rubber band to it. This one holds it very solid. If the link doesn't work just search Ram phone holder.
https://ocmounts.com/products/ram®-q...xoCys8QAvD_BwE
2021 RTL Chrome Deep Marsala
HELI Bars
Garmin Zumo XT
USB power port
Front fender lights & Sequential turn signals
Front LED Auxiliary light
Flashing brake module TricLED
Baha Ron sway bar
belt tensioner
RLS muffler
SpyderLovers Sponsor
TackForm is TOPS
Thanks for everybody's input. I decided to go with the Lamonster RT Spyder Cuff with Lamonster Phone Phang Holder. If I don't like the Phang, the TackForm will be my next consideration.
I’ve used the Phone Phang holder since it first appeared in Lamont’s inventory. It’s seen thousands and thousands of mile on all types of roads. It doesn’t wiggle, holds my phone securely, the phone can be removed with one hand and the price point was great.
2022 Plasma Red, F3 Limited, Special Series
Thanks for giving me some confidence in the product. I made the order yesterday!
Ordered mine today.
2022 Spyder F3L Special Series, Red (Oceanside, CA)
2018 Spyder RT Limited, Pearl White (SLC, Utah)
