Ozzie Ozzie Ozzie
Originally Posted by aka1004
Since rotors are kinda floating on three bolts , how do you make sure it’s properly seated?
Check out pinkrosepetal's posts - IIUC, it's the 'squareness' of the seating on the hub/spindle that's the issue!
So I’ve lowered/soften quite a bit(about 30%) on front shock rebound and that does seem to help, both in acceleration and braking but when I hit the brake hard, rear(not adjusted) got loose.
I soften rear shock rebound sorta matching the front but more testing is needed.
6 states down 42 states to go
