Results 1 to 3 of 3
    Nov 2017
    Western Australia
    Smile New FT3 for $400!
    Just fitted the cat converter delete pipe.
    I can hardly believe the difference. Free revving, especially in the lower gears, seems like lots of extra power, much better ride.
    Like having a new Ft3 for just $400 (ish)
    Baz
    Quote Originally Posted by BazF View Post
    Baz
    Good for you ..... However what you feel is due to what you spent ..... If you had your ECU re-programmed those guys who did the re-program will have added that to their product and will give a boost .... If you are stock, then you only lost 20lb. some extra heat, and nicer sound ..... Mike
    Oct 2020
    Arizona
    Yep, good sound goes faster! Well it sounds faster! Only a dyno or drag strip knows for sure. Without the baffle in the delete pipe you loose bottom end torque. So might even sound better while going slower?
