Greasing 'A' Arms on a 2020 F3 Basic - how?
Need to know if anyone with a newer F3 has greased their own A-Arms? I was under the front end replacing the sway bar and could not find any zerts on the A-Arm pivot points? Did I miss them? Help!! Thanks
Reason: Prefix & title - this is a 'How do I?' question not a 'How To: DIY' guide. ;-)
Those " zerks " dis-appeared from Spyders in 14 (?) .... not needed in the newer models ..... Mike
So, the newer bikes have sealed bushings! No need to grease? Thanks for your input BlueKnight911. One less thing to worry about!
Delayed worry?
Permanently lubricated in an oxymoron.
So very true! Nothing is ever “pernamately” lubricated! Thanks to all for your feedback!
The bushings no longer pivot with a bearing surface. The newer Spyder use shelled rubber type bushings that flex the rubber vs sliding two surfaces against each other.
No lubrication required. Simply replace when worn.
Originally Posted by PMK
The bushings no longer pivot with a bearing surface. The newer Spyder use shelled rubber type bushings that flex the rubber vs sliding two surfaces against each other. No lubrication required. Simply replace when worn.
Newer as of when?
Originally Posted by RICZ
Newer as of when?
2014 and up.
SpyderLovers Sponsor
Not always true. The Delrin bushings I use in my Sway Bar Kits are a special composite plastic infused with a lubricant that never goes away. Well, never is a long time. But 'Never' in the context of the life of a vehicle.
The extensive use of DELRIN® acetal resin as a bearing material has developed because of its combination of low coefficient of friction with self-lubricating properties, good mechanical properties and dimensional stability.
Leading companies across the globe (Hey! I wonder if that includes me?) specify Delrin® acetal homopolymer from DuPont for high-load mechanical applications such as gears, safety restraints, door systems, conveyor belts, healthcare delivery devices, and other demanding products and parts (Like Sway Bar Bushings!).
Ron...I appreciate your addition and you are right. I should have qualified that to greased/oiled parts exclusively.
Ron, thanks for your and others input. Was just not finding any zerts to grease on the a-arms of my 2020 F3 Basic!
Ron, I do love the improvement on handling with your sway bar upgrade! Thanks
