Need dealer to fit shorter brake rod?
Wife was researching moving the foot pegs back, shorter rod. She came up with "need to have the dealer do the work so the Can-am computer can update the bike to the new pedal location"
I'm smelling a major sales pitch there. Please confirm the nonsense.
Ozzie Ozzie Ozzie
That's not a 'sales pitch' you're smelling!! It's pure, unadulterated, but very sloppy bovine faecal matter!
OMG that's bad. It's an easy peasy job to do.
My Mods:
Elka Stage 5 rear shock with spring preload adjust
Monster Stage 2 ECU
Pedal Commander
RLS cat delete
Baja Ron sway bar
Baker Air Wings upper and lower
Viking saddle bags
Third pegs
Vredestein tires front and rear
Mad Stad windshield
X-creen windshield deflector
Front and rear drive cam
Garmin Zumo XT
Heated gear wiring
Lamonster LED headlights
Lamonster LED foglights
Lamonster frame mount cupholder
BRP heated handgrips
Lamonster drivers backrest
BRP passenger backrest
Lidlock handlebar end helmet locks
Barkbusters Storm handguards
Simple job that can be done with normal shop tools and in your driveway.
No computer needed.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
What the rest said. The computer has no idea where your pedal is. I'd run away from that shop FAST but 1st I'd speak with the shop manager and let him know what someone there is trying to scam you over.
Ahhh, read the post......................it was his WIFE that came up with the idea of shop doing it. thats the way it was written, unless he wrote it wrong
F3 it is about a 3 minute job ............ 2 minutes if you have needle nose pliers in your back pocket. I disconnect mine a lot of the time when the brake caliper is off of the disk just to make sure nobody accidentally steps on the brake.
