Results 1 to 13 of 13
Thread: Shoulders hurt
    Feb 2021
    Indiana
    Default Shoulders hurt
    Hi
    I'm new only about 200 miles so far on 2020 RTL Any suggestions on a way to keep shoulders from being sore I'm 5 10 and new spyder Foam grips is the only add if that helps
    I need a lot of practice I know, I came from 40 years of 2 wheelers so far I'm not sure weather I will like it seems to shift me back and forth in seat going down HWY but around town I like it
    Feb 2020
    N. Wilkesboro, NC
    Ease up on your grip and maybe try some different bars so you're a little closer to the grips.
    Sep 2020
    Taxachussetts
    Be sure your grip on the bars show a slight angle on your elbows. Means you are not overreaching to steer.
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    I am worried about the shifting back & forth. Are you having to fight the trike to stay strait? Besides a handle bar adjustment or change I think it is extremely important to have high speed stability. Yes you need a lot more miles under your belt.
    For now definitely stay below 65mph. Make sure your alignment is good. Check your tires pressure. Most importantly do not ride beyond your comfort level. Foam grips are cheap and will help with fatigue.
    May 2019
    Mt. Juliet, TN
    Experienced same type discomfort on 2020 F3-T. installed 2" risers from Lamonster Garage which solved my reach issue I really didn't know I had for long time.
    Apr 2021
    Ky
    I agree about reaching too far and death grip. I need a backrest and windshield.
    OK, now from someone with 12 + years on a couple different model Spyders ..... relax, relax, RELAX ..... Spyders with good alignment will track exactly where they are pointed. ... you have to UN-learn everything you learned on a two-wheel Mtc. .... just drive it like your Car. ... As said above tires should be even with PSI's. ( or very close ) ..... it really takes time in the saddle for most to get comfortable. My advice is DON'T change anything until you learn to handle a Stock Spyder, or you'll be throwing money at it, and decide you didn't need to later ..... good luck & ..... Mike
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    The bars supplied with the 2020RT/RTL have been identified by many as the source of shoulder fatigue and soreness. There are two common and simple solutions: Lamonster's handlebar riser and F3 bars. I chose the F3 bars and the switch solved all of my shoulder/neck issues and provided a more relaxed position on the bike, thereby calming down the twitchy handling. F3T handlebar part number is 709402241, with a price of $109.99. Lamonster's riser: http://www.lamonstergarage.com/handl...020-lamonster/ --~$90.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Feb 2018
    Kerrville. Tx
    Just bought my 2021 RTL in late February - coming off a Gold Wing trike with handlebar risers.
    Worst pain between my shoulders I have ever had with the Spyder. Thought a back rest would put me closer to the handlebars....nope....no relief.
    Jumped in whole hog and put on the $$$Helibars instead of trying this, trying that - totally customized my reach and position.
    LOVE them! No more pain! Worth every $$$ to me.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Not a medical type; however, cockpit ergonomics are generally at play when you have pain in the shoulders. I'm 6'2" and long arms. Had this happen when I owned an '08 1800 Goldwing. Stock seat positioned me too far forward - arms back, pinching between shoulder blades - very uncomfortable. Most bikes and such are designed for the average person of 5'10", give or take a couple - length of a person's upper and lower torso affects this as well. Outside this range you may have comfort issues. Went to Rich's custom seats in Kingston WA, just across from Vancouver Island. He has been doing custom seats for over 25 years. He assessed my requirements and modified the seat such that my seating position was moved 2" back and 2" up, all issues went away. He moved me back to get a better arm position - elbows were now forward of my upper torso, and up 2" because my knee was originally higher than my hip joint - moving me up 2" inches changed this so that the knee was now slightly lower than the hip joint. Better ergonomics all round.
    My 1500 - just sold, seating position was good for the arm placement, but the seat was an inch too low for the hip joint. Had comfort issues in the hip joint because of this. Honda lowered the seating position 1" on the '95 and up GL1500 bikes. It took a while for my hip joint to become uncomfortable so I never had the seat modified.
    If there is a shop nearby that can "fit" you to the Can-Am, wouldn't hurt to visit. You could visit a cycling shop for advice as well, cyclists are into optimizing their riding position for max comfort and performance. Just a thought or two. Last but not the least choice would be to visit a performance snowmobile shop. BRP started in the snowmobile business, changed the traditional seating position from feet forward to the REV platform, more like a performance bike seating position. I find the Spyder with the stock seat to be similar to sitting on a REV snowmobile platform. Just a few thoughts.
    Good luck.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    2012 Suzuki V-Strom DL1000 - on the chopping block
    1995 Honda GL1500 Goldwing - sold - now have room for Spyder
    Ernest
    Feb 2019
    Portland, Oregon
    I must be part orangutan, I am needing bars farther away from my torso. Does BRP make LONGER REACH bars for the F3L?
    I looked to see if I could saw some off of the stock bar, but the cuff is at the curve, preventing that cheap fix.
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    I had pain between my back shoulder blades on my 2020 RTL. Lamonster's handlebar riser relieved my pain. Easy install. I did not have to cut the zip ties holding the cables.
    Feb 2020
    N. Wilkesboro, NC
    Absolutely.
