Results 1 to 21 of 21
Hybrid View
    Active Member boz329's Avatar
    May 2017
    Toledo Ohio
    Default My new f3 got keyed! Help?
    Finally some warm weather... first ride. Gassed her up, went in to pay... some f#^** ass#%& keyed my topcase down to the plastic! (white) Any suggestions how to repair? Pretty sure it was the pickup dude with the Harley decals... and I am a former Harley rider with U.S. Navy vet license plate!
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by boz329 View Post
    Got to love people who don’t respect peoples property......Nosepickers!
    Does the gas station have cameras.....?
    2019 F3L , Covid Blue
    Nov 2018
    Waynesboro, PA
    If you believe that's what happened there will be video of it if you ask. Just saying.
    My Spyder
    2012 RTL , Brown
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    Oh my God. Unreal. Good luck on the solution. Hopefully a camera caught the license plate. Sorry this happened.
    Feb 2019
    Portland, Oregon
    Comprehensive insurance will cover that.
    Well...that's a real bummer. What others have said about insurance and cameras are right on. A little bit of work, but IMO, worth every ounce of effort.
    May 2017
    Toledo Ohio
    I appreciate all the input to find the culprit... but need someone to help me repair myself. Whole new part is $248 from Can Am.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Can Am Parts lists the top case cover as a separate part number so you should be able to order it from your dealer.
    https://can-am-shop.brp.com/on-road/...log-intro.html
    2022 RT Limited , Silver w/ Black and Purple accents
    Sep 2020
    Middletown, NJ
    That sucks. Odds are if you have comp, you have a deductible that won't be met so if you can't find the perp, you're gonna eat the fix.
    2020 RT base , Chalk White
    Aug 2008
    MA & NH
    Sorry that happened.
    PA
    If it’s a deep 1/16 inch scrape/gouge I’d use nail polish. Find closest color and you might have to mix it to match. Then put it on and buff it in. Wipe off and let dry. Repeat the process till it builds up. Small dab goes along way. Don’t put on heavy. Thin little layers and wipe off. Done it on wheelers and it looks like a bad wash job or web markings from cleaning to much. It will not be as notable as the raw scratch. That’s for metallic. If it’s flat then try but it won’t look as nice.
    Mar 2013
    This outfit may have what you need.
    www.scratcheshappen.com
    Change from Auto to Motorcycle and input your year and model. I have gotten both color repair kits for our 2018F3 and 2020RT.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Oct 2020
    Arizona
    Quote Originally Posted by PW2013STL View Post
    Why is it that no one has the Champagne Metallic color that I guess was only a 2017-2018 color.
    Active Member OK-DZ9R's Avatar
    Apr 2017
    Oklahoma
    Touchupdirect.com will have what you need.
    2015 F3 S , Can Am Red
    Florida Swamp
    Advanced Auto and some of the other auto parts places have small, like 4 ounce ding repair paint. It is a small tube with a little brush in the cap. They can match hundreds of car colors for most later model vehicles. You might see if they have anything close to the color you need. A close match and rub it out, you might get it looking pretty good. Cost will be less than $10 with a lot of elbow grease.
    2019 F3-S , Black & Silver
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    First take your bike to an auto paint store that mixes paints for auto body shops ,they should use a special camera to get the correct color match. See if they can make up a spray can of the color you need.
    If the bike was waxed, you will have to get a solvent to remove the wax and oils from you skin. Wipe down area to paint with prep-sol. You will have to block sand ( 400 grit) the area and then apply a thin coat of body filler to build up the surface , block sand the filler it with (320 grit) till smooth Spray the primer with a light gray primer let it dry,(You may have to put a few lite coats on ) block sand the primer with (400) till smooth , scuff the entire area ( Make sure you have no dust on the surface to paint . (Tack rag the area to remove any dust or dirt , if you don't have a tack rag ,Lightly spray a rag with some paint and wipe it down on the area to paint ) several light coats till the primer is covered) then spray the whole part . Depending on the paint you may have to put a clear coat on . If you can not get a spray can made you could buy a small touch up sprayer. Best of luck to you. Hope this helps.
    I don't know if you have a finish master near you , they made paint for my motor home in a spray can.
    Nov 2016
    Upstate NY
    Put a set of stripes over the scratch depending on exact location. I personally would buy the new part for $248. The trike is new. Keep it looking new.
    Bossier LoUiSiAna
    Sorry to hear, replace or maybe good time try a wrap Would consult with professional see if is good option. Please do not let the vandalism go not be addressed by Authorities doubtful will be just but might just be the last straw the law need for such a person.
    Thank you for your service
    It doesn't matter so much who did it. Haters are haters regardless of any other attribute. They are featured on the news every evening.
    I know it's hard. But get it fixed and let it go. Don't allow haters to dictate how you live your life.
    Edit Added;
    I feel for you on this. I did not mean to be hard hearted or uncompassionate. Believe me, I know how it is to have someone callously ruin your day, and your ride.
    You don't say how badly, lengthwise, the illegitimate progeny of that unmarried female keyed the the top. Were I in your boots I'd consider two options; (1) if the gouge is long I'd investigate the cost of a quality autobody shop repainting and clear coating the top in comparison to replacing the part through BRP, or (2) agreeing with Joel, I'd most probably replace the part to keep the new Spyder looking pristine.
    Sep 2015
    JerseyShore
    If the part is only $250 you would be better off buying the replacement part with the matching color. If you took it to a body shop to fix the part, it maybe about $250.
