Results 1 to 16 of 16
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    Default Brand new tires (OEM) Brand new Tire Pressures???
    After getting the tires from the dealer, as I always do, I checked the tire pressures the next day at cold.
    "Ride Now" set the rear at 26PSI and the fronts at 23PSI. I called them questioning the tire pressures and they told me that BRP now recommends these tire pressures.
    Has anyone heard about these new tire pressure recommendations from BRP??
    May 2019
    Port St. Lucie, Florida
    I look forward to the answers you get. When I had my F3t serviced, last fall, they had filled my front tires to about 23 psi, also. I figured it was a mistake, and took air out.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Mar 2021
    AZ
    Quote Originally Posted by carsong View Post
    Interesting. The plot thickens...
    Dec 2018
    Elanora, Qld, Australia
    Me too. 17psi front and 23psi rear I use for one-up ryding. Two-up probably needs higher pressure and my repairer sets them that way. I reset them as soon as I get home.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Apr 2021
    Ky
    21 f3s 15 front 28 rear
    Having trouble posting a picture from the Eye Pad
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    My 2016 and my wife's 2017 F3's are 18 front and 28 rear.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    Jan 2021
    Oklahoma City
    If BRP has changed their tire pressure recommendations they did not up date the 2021 owners manual. My manual for my 2021 RTL says Tire Pressure and Maximum Load is 20 psi front/cold and 28 psi rear/cold found on page 88 and page 146 both.
    Feb 2020
    N. Wilkesboro, NC
    I've got the OEM Kenda on the rear and run it at about 27#. When I had the OEM Kendas on the front, I ran them at about 18#. FWIW, I weigh about 300#.
    Mar 2021
    AZ
    I increased my tire pressure from 17 to 22PSI. Just got back from a ride. 22PSI is definitely too much. It handles better but is bumpy on the highway. I think 20PSI will be the sweet spot. I will try that next. Thanks for all your inputs.
    As far as dealerships, what they suggest is all over the map (I called 3 of them). I called BRP, they said call the dealerships. Ugh!
    Its going to come down to personal preference and experimentation I realize now.
    Probably should have bought different tires to begin with.
    Apr 2021
    Ky
    Quote Originally Posted by AZCanAm View Post
    15/28 if you can't read the owner manual from the 21
    Mar 2021
    AZ
    Quote Originally Posted by Hoginedgewood View Post
    F30D01D4-11E4-4005-A6DF-8C899B46C136.jpg15/28 if you can't read the owner manual from the 21
    Comprehension my man. Comprehension. By the way, its in the frunk as well.
    Thanks for the put down. Feel better?
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    My wife bought a Toyota a coupe of years ago. Door sticker calls for 34 psi. After a couple of weeks of use, I decided to check the tires. I dunno what the dealer delivered it with, but the (cold) tires were still up at 50 psi!
    Northern Kalifornia
    Quote Originally Posted by MONK View Post
    Holy Cow man, that's 2 up! Just kidding you. Some of us are built big and some of us aren't. I run the same PSI 1 up or 2 up. 16 and 20 cold. Our total weight 2 up would be 320#, LLPOF.
    May 2017
    Central Texas
    Quote Originally Posted by Zoot View Post
    The tech checked the sidewalls, they stated "Max pressure 50lbs"... He was probably ASS certified.... LOL
    Mar 2017
    I run 20 up front on my Toyos and 24 on my rear Kumho ECSTA AST 225/50R15.
    Apr 2021
    Ky
    Actually I was referring to the picture of the manual that i posted, it looks fuzzy to me. Im technology challenged. You might find my previous post asking how to post pictures. I personally couldn't read what I posted, later I learned to click my blurry image and it opened clear as day.
