Results 1 to 6 of 6
Thread: Muffler mod
    Active Member Lehrman's Avatar
    Feb 2020
    Violet, Louisiana
    Default Muffler mod
    Has anyone modified the stock muffler on the 1330 to make it louder? Can baffles be removed or drilled out? Any suggestions or is this a bad idea?
    Aug 2019
    Stoughton, WI
    The stock muffler has quite a few chambers in it. Wouldn't be cost effective to destroy it. Cheaper to just get a cat delete pipe..
    2022 RT Sea To Sky
    SoFlo
    Quote Originally Posted by Lehrman View Post
    I have cut open a 1330 RT muffler off a 2014 to 2019 model. There are no true internal baffles. It is a chambered muffler, sort of like a Flowmaster.
    No doubt you could cut it open and remove or drill the chamber walls, but doing so may gain nothing but noise or could even diminish power output.
    Apr 2015
    Lodi WI
    http://www.spyderlovers.com/forums/s...ipes-available
    The muffler on the right is available.
    $100 ?? Just collecting dust. Has at least one sound insert installed. Use with or without cat delete. Not too loud down low but barks a bit starting at 5K rpm.
    Dennis 608-347-7959 for pics or more info? Cost me $650
    Dec 2013
    That link's not working for me Dennis!
    Belay that - found the problem, fixed it! So the link in your post should now work.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2020
    N. Wilkesboro, NC
    According to Shawn Smoak, the F3T/L muffler has a little more growl. If I could find one cheap, I'd try it out.
