Results 1 to 6 of 6
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    Default St-ltd won't upshift
    I noticed today that when I am ready to ride, my 2014 ST-ltd won't upshift from 1st gear until the cycle warms up a couple of minutes, then it is fine. Is this normal ?
    After experimenting a few minutes I realized that as soon as it warms up with 2 bars it is ready to go. I also shift now at 3000 rpm with no problem.
    Thanks for everyones help.
    Bossier LoUiSiAna
    Especially if low on oil. Get up to temp & double check level
    .... and at what RPM's are you shifting ????? .................Mike
    Jun 2014
    Schenevus NY
    And when you check the oil level, be sure to use the proper procedure else it could show low when it really isn't. It's detailed in the owner's manual. Don't have one? See http://www.operatorsguides.brp.com/O...014/2785EN.pdf
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Feb 2012
    Spring City,Utah
    While you are down there checking the oil,check the little shifter arm down low on the left side. It is made of (very) soft metal and if it has loosened up the splines may be worn enough to not allow it enough grip in cold oil to actually effect a shift. Just give it a wiggle for your own piece of mind. If loose see if you can tighten the bolt. If you need to replace, it is about $32.00 but easy to do. Index it to the punch mark on the end of the shaft.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Bossier LoUiSiAna
    Update??
