Results 1 to 6 of 6
    Member rafmn's Avatar
    May 2016
    Shakopee MN
    Default 2021 RT Limited Belt alignment
    I purchased a new 21 RT L, after riding 100+ miles I noticed the drive belt rides on the outside edge of the rear sprocket. If I back up and stop it's close to the inside edge. Put another 150 miles on today and the belt moves back to the outside edge. Anyone else see this on the 21's? It does have the belt idler on it from the factory. It looks like it's installed correctly.
    Thanks Russ
    Aug 2020
    wheatley ,ont
    back axle out of alignment
    Jul 2014
    Mint Hill, NC
    Get it back to the dealership for correction.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    .... about 1/4 turn on the adjuster ..... but it's under warranty let the dealer do it ...... and the drive belt is very long, and it actually moves a bit all the while you are moving ( I've seen video's of this ) ...... good luck .... Mike
    Dec 2020
    Hartwell, Ga
    When you took that photo had you just made either a hard turn left or right? If so that will impact where the belt is. Check it after going in a straight line for a bit. If it's still like that than it need's to be adjusted.
    May 2016
    Shakopee MN
    Quote Originally Posted by K80Shooter View Post
    Nope straight up the driveway into the shed. Also checked through out the ride. Didn't seem to move from that edge other then backing up.
    Thanks for all the responses.
