I would delete the pairings from both the Bike and Phone and pair everything again.
The phone volume is also significantly lower than the radio volume. When you adjust phone volume, it will show as a yellow volume bar and needs to be turned up pretty high.
The headset needs to be paired to the bike only. The phone needs to be paired to the bike only. Pairing the headset to both bike and phone will do this.
thanks for the hints.. I did see that brp connect was in bluetooth 2 times..one is from the previous phone, so I deleted that.. but did not see the helmet..I remember from belfore not to pair to the phone and the bike.. so if deleting one of the brp bluetooth doesn't work.. will delete pairings and try all again..
Rick.
