Results 1 to 13 of 13
    Apr 2020
    Lebanon ohio
    Default Which AMSOIL oil are you using?
    Which Amsoil are you using? 2020 RTL going in for first service, having dealer do first one. They need to fix a couple of small things and having them change to Amsoil oil. Thanks
    Last edited by Peter Aawen; 04-03-2021 at 09:23 PM. Reason: Amsoil oil, not Amalie. ;-)
    Apr 2020
    Lebanon ohio
    Was really wanting to know about AMSOIL oil what WT and I think there is a metric what's the different in the metric oil THANKS
    Sep 2020
    Middletown, NJ
    5w-40 weight full synth.
    Metric oil vs SAE oil : liters vs quarts?
    I think metric is for higher reving engines vs Vtwin 'loppers' but not sure.
    2020 RT base , Chalk White
    Amsoil Metric fully synthetic oil 10W-40 is sold by Bajaron, a SL sponsor. That oil is easily capable of going the OEM prescribed oil change interval of 9,300 miles with minimal degradation of its chemical and lubricating properties.
    Quote Originally Posted by Longtimer View Post
    Amsoil isn't widely distributed or sold at Auto parts stores .... ( I apologize if this has changed ) .... So how are you going to be sure they will use it ... ( even if you bring it to them ) ...???? .... good luck .... Mike
    Sep 2014
    USA
    I am using the 10W40 Metric Amsoil.
    May 2020
    Bunnell Florida
    Amsoil Metric fully synthetic oil 10W-40 is sold by Bajaron......i Change my oil and filter ever January...regardless.....this Jan 2022 i am going to remove the frunk and clean the radiator fins..change out the anti freeze and throw in a new battery which i change out every two years regardless...bleed out the brakes as well..
    Northern Kalifornia
    Me 2. You can get Amsoil through BajaRon or direct from Amsoil. Either way, the price is the same. Ron does not charge extra, he just forwards your order on to Amsoil. Ron is a good guy to deal with.
    Aug 2019
    Stoughton, WI
    The (3) metric dealers and (1) H-D dealer in my area all carry Amsoil m/c oil.
    2022 RT Sea To Sky
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    To make things super easy for you contact BajaRon.....he'll set you up with the correct oil
    2019 Phoenix Orange RTL
    LED head lights, LED fog lights, Lidlocks, Brake light kit, Sway Bar, J&S Jack, Cat Delete, Akrapovic silencer, Idler pulley Kit, Gold Drain Plugs, Magic Mirrors, Bumpskid, Tires, Centermatic balancers, Wick-it Stage 1 tune, Convex mirrors, EBC Brake Pads, EBC brake Rotors, Speed Bleeders, M-2 Custom Shocks, Odyssey Battery, Tinted Windshield, Windshield Arm, Gps Ultimate Seat, Dual air Horns, Modesta BC05 Ceramic Coating, Redline 10w40 motorcycle oil, BRP Passenger arm rest, BRP hitch, Syderpop rock guard 2015 Freedom Trailer
    100% True Synthetic. Very few lubricants can say this. It does make a difference.
    Nov 2018
    N.E. Ohio
    That’s exactly what I use and exactly where I buy it by the case with filters for my 2019 Ryker Rally with wonderful success. I’ve been using Amsoil for years in my Goldwing and Harley. IMHO, none better!
    Mar 2020
    Santa Clara ca.
    im using Motul 7100 10/40.
