2018 limited F3.. what goes on when the top case is removed
Hi! I have wondered the same thing...I *think* if if you go to cheapcycleparts.com and look there it would be under the parts for an F3 T. Because removing the top case on the F3 L essentially turns it into an F3 T, right? So I think ordering the back cover for an F3 T might do the trick. Hope that helps! If you end up ordering it, let us know if it works!
