Hi Buddy,
Yes Pedal Box that you can buy on my shop
https://www.martinthevlogger.com/pro...-rotax-engines
will work on any 998 from 2010, as there was a switch to electric throttle and this is what PedalBox unit need.
Why I say on my shop, is not because its a sales pitch. However somebody wrote on different post in general group, that he has bought a PedalBox and it causes errors.
I dont know where that person have bought it, but definitely not from me as he said - from someone from US... PedalBox is being used in different vehicles, and what is important is the map that is recorded inside.
Guys in Germany has spend months on different SPYDERS to test it and adjust it so its error code free and works on 998 engines.
Actually in 998 it will work more aggressively than on 1330 engines
as for ECU - it will no mess with it. it has nothing to do with ECU.
what it will do, is it will unlock the throttle. Now when you pull the throttle to max, it will still be open max to 65%. Not more.
so whatever you will do, the SPYDER will use just 65% of the map that is recorded in ECU.
with PedalBox and different modes, in the most aggressive mode, it will open to 95%.
so will you accelerate faster - YES
will you hit higher speed - NO
Will you be able to cross the red lights RPM - NO
is it fun - hell YES
