Results 1 to 6 of 6
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default 2021 RTL mirror removal - is it easy?
    I might want to take it off to help with an LED install.
    Looks easy enough... is it?
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Feb 2020
    N. Wilkesboro, NC
    Smack the bottom of it to pop it free from the (2) lower pins then lift up.
    Sep 2020
    Middletown, NJ
    While you have them off, you may want to replace those pins with one of the mirror anti-shake fix options.
    2020 RT base , Chalk White
    Nov 2016
    Upstate NY
    On the 2021, you need to pop off the mirror cover first. Pull towards front of bike. A plastic prying tool helps. Next, remove the small torx screw on the end of the mirror and slide the mirror part off. Next lift up and remove the small dash filler piece. Now you can lift up on the end off whats left and pop it off.
    Feb 2017
    Quote Originally Posted by Joel The Biker View Post
    On the 2021, you need to pop off the mirror cover first. Pull towards front of bike. A plastic prying tool helps. Next, remove the small torx screw on the end of the mirror and slide the mirror part off. Next lift up and remove the small dash filler piece. Now you can lift up on the end off what's left and pop it off.
    Absolutely how is should be done on a 2021 RT. You can also look at Lamonster's or Pierre's videos about their mirror vibration dmpers - they're detailed and easy to follow.
    Jul 2010
    Las Vegas, NV
    No smacking!
    Joe Meyer
