Results 1 to 10 of 10
    Mar 2021
    Idaho
    Default How do you Remove the Rear Seat on a 2020 Spyder RTL?
    How do you remove the rear seat on the 2020 Spyder RTL? The manual says to unlatch the two (2) latches, but I can't figure out if they pull out, push in, go the side, etc. (I've tried all of these). The manual is so vague at times that it's useless. Any help is appreciated.
    Thanks!
    Aug 2020
    Creal Springs, Illinois
    Push the tabs. One on each side. And I agree it is not clear.
    Mar 2013
    Maumelle, AR
    Look under the seat with a flashlight to see the tabs. Push them in just a fraction of an inch and lift the front of the rear seat. It should come right up. If you have a backrest, that needs to be removed first.
    2020 RT Limited , Chalk
    Mar 2021
    Idaho
    Got it! Thank you! The wife thanks you - the armrests are installed now.
    Nov 2016
    Upstate NY
    Even easier, just grab the two front corners and give it a tug. Pops right off. The dealer tech showed me that. I asked him about pushing the tabs he said nope, just give it a tug. I have removed mine at least 15 times this way.
    2021 Sea to Sky RT , Highland green
    Dec 2020
    Hartwell, Ga
    I had the dealer replace mine just for that reason, they had removed it that way and it wouldn't lock back. I don't think it would have came off but like I told them, that's not the way it's supposed to be done.
    Then again, it's your bike do what you want and enjoy it.
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by K80Shooter View Post
    I tried the same thing on mine. They refused stating it's normal to be able to just pull it up. They even showed me on a new bike. I told them, if it's meant to just pull up, why are there locking tabs. They didn't have an answer and again refused to do anything about it. I have a backrest so I KNOW it won't come off on it's own but it should still be replaced under warranty.
    Sep 2020
    Middletown, NJ
    Please ID that 'dealer'! I want to be sure if I'm ever in the area that I bypass a ham-handed troglodyte shop.
    2020 RT base , Chalk White
    Mar 2013
    Maumelle, AR
    Early on, my tabs were broken. They'll break if not installed properly.
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Quote Originally Posted by triggerpull View Post
    It helps if you push down on the front of the rear seat while pushing on the tabs one at a time.
