Results 1 to 5 of 5
    Oct 2017
    Kent, Ohio, USA
    Default Can I Disable the air-pump to the bladder raising the rear?
    I replaced the rear shock absorber for my 2014 RT with an Elka when the pump to the raise/lower bladder couldn't keep pace with a leak. Problem Solved!
    But, the pump continues to cycle every 45-seconds or so.
    My question: Is there a way I can <easily> disable the pump mechanism so as to stop the annoying noise?
    Caven
    Caven Mcloughlin; caven@kent.edu
    Aug 2020
    wheatley ,ont
    if pump is still cycling,,,you must still have an air leak in the system some were
    Oct 2017
    Kent, Ohio, USA
    Brad: Yes. I'm sure that I still have a leak because I didn't address the leak I only added an Elka shock.
    The pump is continuing to attempt to inflate the bladder ... but the noise it makes is irritating. Is it possible to disable the pump (perhaps by cutting its power)?
    Best wishes, Caven
    Aug 2019
    southwest oHIo
    I don't have a manual in front of me, but might it be as simple as pulling a fuse?
    I don't know if the pump is on its own fuse or shares the circuit with something else.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Yes take out the relay or fuse in the front trunk
