Results 1 to 6 of 6
    Aug 2018
    Maryland
    Default Latest 2018 RTL Software Version
    I’ve got to bring the bike into the shop, and I wanted to be sure of the latest version—is it still 20.8?
    Many thanks in advance.
    2 2018 RT Limiteds (Blue and Gold (Champagne)), dual flagstaffs, KOTTs grills, foam grips
    2018 RTL , Blue
    Sep 2009
    La Valle, WI
    Yes. Nothing newer yet.
    2018 F3 Limited , Oxford Blue
    Aug 2013
    SF Bay Area
    Hopefully you will get an update. The 2018/19's as well as the 2020's should get an update. If not, then we need to demand it.
    2021 F3 Ltd , Magna Red
    Sep 2009
    La Valle, WI
    The 18-19 have a different software number than the 20-21 do. I believe there's are 30.2
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    How can I check the software version on my 2019 RTL?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Mar 2021
    Arizona high country
    on an F3 you go to the configuration menu and it will tell you what release you are on. I would think the RT would be the same way.
