Results 1 to 5 of 5
    Active Member spyderryder53's Avatar
    Hanover CT
    Default Brake light switch
    Has anyone replaced the BLS , with anything other than rivets like screws or zip ties?
    Thanks in advance
    Leon
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
    SoFlo
    Quote Originally Posted by spyderryder53 View Post
    Thanks in advance
    Leon
    Dumb design, but certainly production. I would not use zip ties, they will eventually work loose in that application. I would use correctly sized screws and lock nuts.
    Hanover CT
    I was thinking the same about zip ties .I'll get screws and lock tite or pick up a rivet gun.
    Thank you PMK
    AND
    SoFlo
    Thank you PMK
    Not Loctite, get some nylon locnuts.
    Hanover CT
    Will do thanks
    AND
