Results 1 to 4 of 4
    Mar 2021
    Arizona high country
    Default Ram mount using handlebar bolts
    I know I saw a handlebar bolt that had a Ram ball on the end, but can't seem to find them. Anybody remember who sells them?
    Nevermind. I finally found it. www.canamspyderaccessories.com
    Aug 2019
    Stoughton, WI
    I think the Spyder handlebar bolts are bigger, as I did try this with some I had.
    2022 RT Sea To Sky
    Oct 2015
    Lynden, WA
    I just purchased 2 of these Ram Balls for my F3T.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    You will need longer bolts - Metric socket cap, Stainless steel 18-8 (A-2), 10mm x 1.5mm x 65mm.
    Bolts are available from https://www.boltdepot.com/Product-De...x?product=6473
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2019
    Deltona FL
    I purchased my setup from Slingmods.com You have choices on which kit is your preference.
