Results 1 to 2 of 2
Hybrid View
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Default Is it possible to fit Airride to a Spyder F3s?
    Been surfing the net, but cannot find any info, If it's possible to fit airride to a F3s Spyder, we ride double up, but I drive also one up.
    On occasion the tire rubs the inner fender, now I am not looking for a stiffer ride, but want to get rid of the annoying tire rub.
    Here in the netherlands, there are alot of speedbumps, and riding double up, then at speed, the tire rubs the inner fender..
    My thought would be, to get the airride from an F3t, and retrofit that to my F3s, should I take something in considering...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    Here ya go.
    "https://platinumairsuspension.com/product/air-ride-canam-spyder-bleed-feed-kit/"
