Results 1 to 14 of 14
    Jan 2015
    southern WI
    Default Anyone tried "Speed Bleeders" brake bleeders?
    Has anyone tried these on their Spyder?. I just changed my brake pads and was thinking about flushing a bit of the old fluid out. Wondering if anyone has any reviews on this style bleed system..
    http://speedbleeder.com/feature.htm
    2016 RTS , Pearl White
    Feb 2020
    N. Wilkesboro, NC
    Never used Speed Bleeders on either of the RTs but I've had them on just about everything else I've owned (except for the current leased Honda CR-V). If you want to work on the brakes or clutch and you don't have someone else to assist, this is the only way to go.
    There's quite a bit of discussion about them & their use here already - most of it strongly supportive! A basic search on 'Speed; + bleeders' shows quite a few pages of information:
    https://www.spyderlovers.com/forums/...archid=2077889
    Mazo, you mean you have really missed all the good discussions about them on here over the past few years? I can hardly believe it!!!!
    Here's what I recently posted about doing a brake flush. https://www.spyderlovers.com/forums/...ush-the-system. In post number 12 I say,
    Got the flushing completed today. First off I gotta say Speed Bleeders are the cat's meow! They make the bleeding process almost fool proof!
    There are several other positive comments regarding Speed Bleeders in the preceding posts. Get them! You won't go wrong!
    Mar 2019
    NEBRASKA
    Look...the speed bleeders are God's gift to the DIY brake flush....there is no way to do it without someone helping unless you have speed bleeders and installing these is no issue whatsoever. These allow you to do the flush with no worries about getting air into the lines. Do it!! If your cheap....just buy one bleeder and move it around each caliper...but these are about 7$ so its 21$ plus I thinks 5-6 $ shipping.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Jan 2015
    southern WI
    Yeah, I guess I totally missed this.......maybe I dozed off for a while.
    Oct 2015
    Lynden, WA
    Speed Bleeders are GREAT. I installed a set on my previous 2013 STS.
    I will be installing a set on my F3 at the first major service interval.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2015
    forrest above Reno, Nv
    A big +1 on the speedbleeders.
    2014 RTS , Circuit Yellow
    Aug 2019
    Stoughton, WI
    As above, I have used them on my past bikes, and they work great. That said, when the time comes to flush out the old fluid, I will be adding the bleeders
    2022 RT Sea To Sky
    Very Active Member Pandy's Avatar
    Mar 2011
    Lake Wylie South Carolina
    +1 on Speedbleeders. Just replaced rear pads and flushed. IMHO worth a try.
    David
    2011 RTS 2006 Yamaha Morphous
    Nov 2015
    Myerstown, Pennsylvania
    I'm overdue for my brake fluid change. It was supposed to get done last fall but I'm doing it now. SpeedBleeders are on the way and I hope to have them before the weekend. Using a vacuum pump works but is a PITA. I just got done putting gel pads in my seat too. Driver and passenger. Can't wait to take it out to see how it feels.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Just installed mine over the weekend and bled with new brake fluid......super easy to do.
    2019 Phoenix Orange RTL
    LED head lights, LED fog lights, Lidlocks, Brake light kit, Sway Bar, J&S Jack, Cat Delete, Akrapovic silencer, Idler pulley Kit, Gold Drain Plugs, Magic Mirrors, Bumpskid, Tires, Centermatic balancers, Wick-it Stage 1 tune, Convex mirrors, EBC Brake Pads, EBC brake Rotors, Speed Bleeders, M-2 Custom Shocks, Odyssey Battery, Tinted Windshield, Windshield Arm, Gps Ultimate Seat, Dual air Horns, Modesta BC05 Ceramic Coating, Redline 10w40 motorcycle oil, BRP Passenger arm rest, BRP hitch, Syderpop rock guard 2015 Freedom Trailer
    Sep 2009
    La Valle, WI
    Quote Originally Posted by davev1pa View Post
    If you have a vacuum pump with fluid reservoir you can do it by yourself. That's how I do it.
    2018 F3 Limited , Oxford Blue
    Nov 2015
    I just did my brake bleeding with speedbleeders and I can just say that every spyder and motorcycle owner should have them. Bleeding my spyder took half of the time this time around. Ready to ryde!
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
