Results 1 to 7 of 7
    Mar 2020
    Cumming, GA
    Default Dummy acc plug on left side of Ignition key on an F3s
    I noticed when I remove the acc (dummy) plug on the left side of ignition switch there is a wire attached.
    It has 2 black 1 blue, and 1 orange going into a plastic looks like 4 outlet connector.
    WHAT is that for? Is it for an accessory?
    I want to install a volt meter in that area and maybe I could use part of that harness, or not!
    I have called BRP, and no less than 4 dealers in my area and NOT 1 can tell me what that harness is for or connected to.
    Thanks,
    Rotax
    Oct 2015
    Lynden, WA
    Left side is Heated Grips.
    Right side is Fog Lights
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2020
    Cumming, GA
    Thanks David!
    Can I utilize that connection to connect a volt meter
    in that space?
    Suggestions.
    Rotax
    Mar 2020
    Cumming, GA
    David,
    I don't need the heated grip option.
    I would need to find the male connection for that accessory without
    the heated grips?
    Rotax
    Oct 2015
    Lynden, WA
    Rotax,
    What you need is a 4 Position MX19 connector.
    Sorry, I don't have a source for this part.
    You can check http://www.cycleterminal.com/
    I made a male from computer parts for my fog lights.
    David C.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Mar 2020
    Cumming, GA
    Outstanding David!
    Will investigate that connector however I will only need two
    wired of the 4 for the volt meter.
    Hate to impose on you, but do U know which 2 wired, +/- that will
    allow me to hook up the volt meter?
    Again, THANKS for all the info!
    Rotax
    Oct 2015
    Lynden, WA
    Default Left Side Connector.
    Sorry i have not worked on the Left Side Connector.
    After looking at the wiring diagram (very confusing) I would not try to run a voltmeter from the Grip heater plug.
    I believe the plug wiring runs to switching relays and other component in the fuse block. It may not show the true voltage.
    I would wire directly to the battery or to one of the Customer Accessory terminals in either the back of the frunk or under left side panel.
    David C
    2016 F3T
    Rear IPS Pack Rack
