Results 1 to 11 of 11
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default 2014 998 ST SE5 Coolant Leak
    Hi all hopefully someone can direct me in the right direction. When my wife’s 2014 ST sits over the winter just before coming out of hibernation there’s a coolant leak. Funny it does go away after it’s been run for a bit. I pulled the right side cover off and can’t really tell or see where it may come from. Do I need to pull the bottom black panel as well or what panels need to be pulled to get a good look at the coolant tank. Thanks much for any and all help with this project.
    Model: 2014 ST SE5, 998 engine
    Thanks,
    Michrick
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
    Clinton, MS
    Sounds like a classic case of a cold weather leak at a hose clamp.
    May 2015
    Liverpool, NY
    Yeah but to change them all or get a better look I think more panels need to come off the ST, the clamps aren’t the worm gear style they are crimped on.
    Thanks for your response
    Michrick
    Hers 2014 ST
    His 2016 RT Limited
    INDIANA, USA
    Default Coolant Leak
    Coolant leaks can be found with a little patience and preparation. Yes, you will need to remove some of the plastic pieces. You stated that it only leaks during the 'winter lay up season'.
    Check your coolant level and see if it is low. How much? What color is your coolant? The orange color coolant will leave a 'white stuff' marking as it dries. Do you see any 'white stuff'?
    I had a water pump that was weeping and it was hard to get to and see. Let us know what you find. .....
    ENJOY YOUR LIFE WITH A SPYDER
    May 2015
    Liverpool, NY
    Thanks Little Blue my coolant is orange in color. We took it out yesterday for a short 40 mile ride. I told my wife keep an eye on the temp gauge. The bike never overheated and checking today nothing under it. I’m going to take all the RH plastic off and the belly pan for a better look. Thanks for your advice on what to look for. It sure is tight in there.
    Michrick
    Hers 2014 ST
    His 2016 RT Limited
    Jun 2014
    Schenevus NY
    Quote Originally Posted by michrick View Post
    Michrick
    If your 2014 is like mine, there is one worm gear clamp and that's where my cold-weather-layover leak was coming from.
    It's at the top of the water pump on the right side of the bike.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    May 2015
    Liverpool, NY
    Thanks Trbayth I will check that area this weekend.
    Hers 2014 ST
    His 2016 RT Limited
    Jan 2021
    Martinsburg, WV
    I bought my 2012 SE 5 in January. Had a buddy trailer it home....21 degrees when we picked it up in NJ.
    After sitting un-started for 3 weeks mine "pee'd" on my garage floor. After the weather warmed up I added some coolant to bring it back to the full line. Just a few ounces.
    Mine was green. To see the coolant tank I opened the frunk and removed the small black cover and could see the tank from there.
    But oh what a PIA to fill.....LOL
    Hasn't moved off the full line ever since. Been riding it several times a week for the last 3 weeks.
    I chalked it up to a cold weather seal leak.
    May 2015
    Liverpool, NY
    Thanks porkchop1965
    Hers 2014 ST
    His 2016 RT Limited
    Nov 2015
    Chardon, OH
    All 998 V-Twins also have two more screw type clamps up close to the block nestled right under the air box. They can be a source of leakage, also. You will get intimately frustrated trying to get to them, usually working by feel. But, all it takes is a turn and they stop leaking.
    Doug
    ”Freedom is not a loophole”
    May 2015
    Liverpool, NY
    Thanks Snowbelt Spyder I will try and locate them
    Hers 2014 ST
    His 2016 RT Limited
